How to lower the rear end a bit
Old Nov 2, 2008 | 12:43 PM
86C4VETTE's Avatar
86C4VETTE
Default How to lower the rear end a bit
Ok guys got a question. I want to lower the rear of my 86 vette. I am lookng to just even things up a bit, there is to much gap between the well and tire. Any recommendations?
Old Nov 2, 2008 | 12:59 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
I used the lowering kit. Just replacement bolts for the rear spring. Can get them at any of the fine Forum Sponsors, Ecklers, Corvette Central etc... Would take about an hour to install, then should get a rear alignment.
Old Nov 2, 2008 | 01:05 PM
86C4VETTE's Avatar
86C4VETTE
Thanks! I saw the kit that Mid-America has, I will check it out.
Old Nov 2, 2008 | 01:09 PM
Calderone's Avatar
Calderone
Thanks! I saw the kit that Mid-Atlantic has, I will check it out.
Yes,i got the kit from Mid-Asia too !
Jokin aside,you can get the kit there or from Ebblers
Old Nov 2, 2008 | 01:15 PM
86C4VETTE's Avatar
86C4VETTE
Thank you sir!
Old Nov 2, 2008 | 04:41 PM
LKoncar's Avatar
LKoncar
If your bushings are good you just need the bolts. This is what I used
http://www.ecklers.com/product.asp?p...3&dept_id=1822
You will need to get an alignment also
Old Nov 2, 2008 | 05:08 PM
Road Agent's Avatar
Road Agent
I run 15 psi in the rears and 40 front. It not a problem!
Old Nov 2, 2008 | 05:27 PM
86C4VETTE's Avatar
86C4VETTE
Old Nov 2, 2008 | 05:28 PM
86C4VETTE's Avatar
86C4VETTE
Thanks, good price there!
Old Nov 2, 2008 | 05:32 PM
ekess744's Avatar
ekess744
air bags huh?
To How to lower the rear end a bit
