Knock sensors
Old Nov 3, 2008 | 04:58 PM
saoco's Avatar
saoco
Default Knock sensors
Can knock-sensors pick up clucth chatter and retard the timing in an engine???
Old Nov 4, 2008 | 12:17 PM
cmcbunch's Avatar
cmcbunch
Im not sure but I wont rule it out. I know a gear driven camshaft will drive a knock sensor crazy.
Old Nov 4, 2008 | 12:41 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Never heard of clutch chatter being an issue, but the KS is just a tuned (for 5-6 kHz) microphone, for all intents and purpose. If you're somehow causing some mechanical noise of significant amplitude, there's always the possibility that a sufficient portion of that noise may be in the 5-6 kHz range, causing the ESC to call for retard.
Old Nov 4, 2008 | 11:50 PM
saoco's Avatar
saoco
Just to be on the safe side I will turn both ks off. Thanks guys!!!
To Knock sensors
