90 C4 coupe flashing 'sys' error
Old Nov 4, 2008 | 08:22 AM
mctabares's Avatar
mctabares
Cruising
Default 90 C4 coupe flashing 'sys' error
My 90 c4 now displays a flashing 'sys' error on the digital display but I can't find any info on the factory service manual, has anyone got any idea what that relates to.
Thks.
Old Nov 4, 2008 | 08:57 AM
jispr's Avatar
jispr
VERY common code. Low voltage. Start with the battery. I get the code sometimes if the car sits for a week, goes away after driving awhile.
Old Nov 4, 2008 | 10:23 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Your battery is lacking. Do you use a battery tender or other device to keep it charged while the car sits for extended periods of time?
Old Nov 5, 2008 | 04:19 AM
mctabares's Avatar
mctabares
Cruising
Yep, that sounds right, the car has hardly been used in the last year, and I regularly connect a very good european made monitoring tender called 'Optimate' but I noticed recently it came up with a red light indicating poor battery condition, athough last week Charged ok. The battery is just 5 years old so I guess it's time to change it. Thks folks.
To 90 C4 coupe flashing 'sys' error
