SES Light. Help Please
Old Nov 4, 2008 | 11:15 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default SES Light. Help Please
I live about 200 miles away from where I go to school. Taking the drive this weekend, about 1/2 way the SES light came on. No other lights, car has full power, but when I shut the car off and then on it goes away. Sometimes it comes back on and sometimes not. I have done the following to my 1990 Z51: 30lb injectors, ZZ4 cam, LT4 springs, no mufflers. After all this I had a chip burned and it ran great. I removed the EGR valve and tube but it was not on the tune. Would this cause a SES light?
Old Nov 4, 2008 | 12:47 PM
rick lambert's Avatar
rick lambert
Check for stored codes. I've heard that removing the EGR can cause a code to be thrown, but you'll never know what it is until you check for codes.
Old Nov 4, 2008 | 12:56 PM
janarvae's Avatar
janarvae
If you pull the codes and it is the EGR, IIRC, you can put a diode in the circuit that tricks the ECM. Check out this forum member's personal website here for more info on 'faking' the EGR system.
Old Nov 4, 2008 | 01:09 PM
Yorcci's Avatar
Yorcci
Probably EGR is giving you the code (that would be 32). Check out, which code is set. This is a bit too late advise, but you should have had the EGR diagnostics turned off when you had the chip burned:
Old Nov 4, 2008 | 04:27 PM
Kubs's Avatar
Kubs
Thanks. Yeah I didnt think about the EGR until after the chip was burned. I am doing some mods this winter and will have the EGR added to the list for the re-burn.
To check codes I can put a jumper between pins A and B and turn the key to on correct? Then the SES light flashes the code? Its been a while since I diagnosed a car this way so I am tring to refresh my memory.
Old Nov 5, 2008 | 04:41 AM
Yorcci's Avatar
Yorcci
Yep. First it flashes code 12 three times, after this come all stored codes and after all codes have been flashed, again code 12. And then the cycle starts over.
Old Nov 6, 2008 | 02:18 PM
Kubs's Avatar
Kubs
Ok I finally got around to pulling codes and I got 32 (which stated before is the EGR) and 41. I dont know what 41 is because I dont have a manual. Does anyone know or can tell me where to look it up?
Also, I was driving around town and when the SES light comes on the car stumbles under load such as hard acceleration. Would a code 41 make this happen?
Old Nov 6, 2008 | 02:27 PM
Nathan Plemons's Avatar
Nathan Plemons
From Alldata:
Code 41
Cylinder Select Error
(Faulty or Incorrect Mem-Cal)
Basically it sounds to me like your custom computer chip needs to be reseated. It sounds like under hard acceleration it might be making intermittent contact.
Old Nov 6, 2008 | 02:31 PM
Kubs's Avatar
Kubs
Thanks! I will look at it. It didnt seem all too tight when I put it in. Is there a way to make sure it stays in better if this is the issue?
Old Nov 6, 2008 | 02:58 PM
Kubs's Avatar
Kubs
It turns out it was loose. Can I put something like a paper towel in between the ECM lid and the chip to keep it from coming out again? That chip wont get hot enough it ignite the paper towel will it?
Old Nov 6, 2008 | 03:16 PM
Nathan Plemons
I wouldn't think so but I would suggest something non flammable, or with a much higher ignition point. Something plastic or leather might work.
Old Nov 6, 2008 | 03:19 PM
Kubs's Avatar
Kubs
Thanks!
To SES Light. Help Please
