Fuel pump
Old Nov 5, 2008 | 04:04 PM
tooez's Avatar
tooez
Default Fuel pump
Is their a way to check the fuel pump. Can I just put power to the grey wire and ground the black. Will the pump work if its good.
the vette is a 1990.
thanks in advance.
Old Nov 5, 2008 | 05:11 PM
JAKE's Avatar
JAKE
You can use a paper clip; insert it into the ALDL connector (under the driver's side of the dash) and the pump will energize (come on) if it's good.
I forgot which terminals to use, but I'm sure someone will post them; probably a diagram too.
Jake
Old Nov 5, 2008 | 07:17 PM
car5car's Avatar
car5car
thanks in advance.
Yes if you know right wires
Old Nov 5, 2008 | 08:10 PM
JackDidley's Avatar
JackDidley
Giving it power can make it run, but you may want to use a pressure guage to see how well its working. To really test it, you can hook up a guage and tape it to the windshield and watch it while driving.
Old Nov 6, 2008 | 03:11 AM
tooez's Avatar
tooez
Car has been tore down for about 2 years. I have been doing the paint and the interior. I put the battery in it and it's not getting any fuel. It starts right up if I put fuel in TB. Car ran perfect when I parked it. Any help would be helpful. Thanks
Old Nov 6, 2008 | 06:05 AM
aboatguy's Avatar
aboatguy
Using a guage is the best way to test a fuel pump!
Old Nov 6, 2008 | 11:44 AM
rick lambert's Avatar
rick lambert
1990 was still an OBD1, with the 12 pin ALDL, MAKE sure you confirm the fuel pump pin, but on earlier OBD1s you can run a wire from the positive side of the battery to pin G, lower row on ALDL on the left side, should only be one pin there, that will bypass the fuel pump circuit and power up the pump (if it's still good).
You said you were working on the interior, did you remove any fuses?
Old Nov 6, 2008 | 04:10 PM
tooez's Avatar
tooez
No I didn' remove any fuses. I just put all new carpet it, new door panels, new door sills, and new radio bezel. I ran a hot wire to the ALDL and the pump didn't come on. When the car had been sitting for about a month, I heard a clicking coming from the passenger side of dash. So I unhooked the battery. I was thinking maybe the relay was bad but I should still be able to bypass and hear it run. I will get a new relay and pump and go from there. Thanks everyone.
Old Nov 6, 2008 | 06:10 PM
Da Mail Man's Avatar
Da Mail Man
To Fuel pump
