1st trip to dyno--any advice?
its a mustang dynamometer
they offer baseline test--3 runs
and baseline w/ wideband--whats this?
the shop does mostly imports
any advice is appreciated
matt
matt
dyno runs
hi, i just got back from a dyno tune at Henderson Performance. before i went, i replaced the o2 sensors, knock sensors, did an oil change and fuel filter change, checked exhaust for any leaks, filled all fluids, checked u-joints and adjusted valves. also checked tire air pressures and replaced spark plugs. if you go fully prepared you will get a fairly true horse power and torque reading, go home much happier and not have to begin repairs and guess at the repaired problems output of your engine. hope that this will help. also, take a video recorder so you can enjoy the runs later.
My only advice is be prepared to expect the worst. Most people come out crying after they leave mustang dynos because they read lower (some of them I should mention) than traditional dynojets.
