lq9
Old Nov 7, 2008 | 04:07 PM
fast383vette's Avatar
fast383vette
Default lq9
has anyone drop a lq9 in a c4 vette....just wanted to see if anyone can give me a link...thanks
Old Nov 7, 2008 | 04:11 PM
Nathan Plemons's Avatar
Nathan Plemons
I doubt it, but if you use the search you can probably find a thread or two where people have done an LS1 swap. I imagine they'd be really similar if not the same.
Old Nov 7, 2008 | 09:00 PM
Slalom4me's Avatar
Slalom4me
Make yourself comfortable. Some of the better threads
on the LSx/LQx follow below
The players:
- CHarris85vette (aka Cory@LS2PortWorks)
- kpforce1
- 69Myway
- Jeffvette
- TracerX
And the first person to post about completing this swap, LS1Tuner:
Old Nov 7, 2008 | 09:42 PM
BAM92's Avatar
BAM92
Now an LS9 would be fun. Have to change the hood though.
Old Nov 8, 2008 | 05:02 AM
fast383vette
all the engine swaps are ls1 or ls2....i want to do the lq9 with a carb kit and for right now run my 700r4...later ill get the th350 or 400.......they mke motor mount for a lsx swap ill use those..
( http://www.speedhound.com/lsxswap.html ).....and the carb kit bring a mouth to use the 700r4
http://www.jegs.com/p/Edelbrock/755239/10002/-1
....the thing is what would i need to do to my chassis.....im not useing the ac ...the only thing im useing would be powersteering,and alternator.......
Old Nov 8, 2008 | 02:20 PM
BAM92's Avatar
BAM92
As said above, it looks like the LQ and LS are similar swaps. Looks like you are going to be the first with the LQ though. So any particulars you probably going to have figure out as you go. Did a google search on LQ9's, tons of stuff mostly f body, older cars/trucks and C5s though.
Old Nov 8, 2008 | 04:04 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by fast383vette
All the engine swaps are LS1 or LS2....I want to do the LQ9
This is incorrect.
The first link 1991 Vert with 6.0 LS1 in progress is about an LQ4.
Originally Posted by Cory@LS2PortWorks
"... I've been working on this project for a little over a month now.
A low mileage Iron 6.0 (LQ4) came to me ..."
An LQ9 is an LQ4 with some enhancements. Both are Fe block/Al head
combinations.
6.0L (101.6 mm x 92 mm)
- 364ci (4.000" x 3.622" w/ 6.098" rod)
LQ4: Fe/Al 300-325HP/360-365TQ @ 4400-5200/4000; 9.4:1 CR
LQ4 camshaft specs
- 99-00 (PN 12560967): 0.457"/0.466"; 191/190 @ 0.050"; 114 LSA
- 01-06 (PN 12561721): 0.467"/0.479"; 196/201 @ 0.050"; 116 LSA
LQ9: Fe/Al 345HP/380TQ @ 5200/4000; 10.0:1 CR
The LQ9 uses the later LQ4 camshaft.
Old Nov 8, 2008 | 07:12 PM
fast383vette
well im going to go for it...i get the motor for $900..and my l98 doesnt run or start....and i dont care if i have to cut it up to make it fit...ill make it my race call(have my lightning as the DD)...
plans or lq9 to a carb 408 small block ...a quadzilla 4L80 tranny manual shifting...and a dana44 in the rear.....its going to cost like 10K....
i wanna make custom gauges too..im not going to have a/c...should be fun ill put pic up when i start...ill also be saleing thing off my 87 auto so ill put some parts up
Old Nov 8, 2008 | 07:26 PM
Corvette Chris's Avatar
Corvette Chris
Make sure you post pics and keep us updated.
Old Nov 8, 2008 | 07:50 PM
fast383vette
will do...lots of pics......ill run the 700r4 at 1st...then ill upgrade it...what ever it takes ill make it fit ....
Old Nov 8, 2008 | 07:51 PM
Corvette Chris
You're the man. Just what I wanted to hear.
To lq9
