C6 rims on 89 C4?
Old Nov 7, 2008 | 08:47 PM
89corvetteken's Avatar
89corvetteken
Default C6 rims on 89 C4?
I was wondering if anyone knows if 05 C6 rims (wheels) will fit on a 89?
Old Nov 7, 2008 | 09:12 PM
Corvette Chris's Avatar
Corvette Chris
They should fit.
Doesn't matter, yours sits on stands minus wheels most the time anyway.
Old Nov 7, 2008 | 09:17 PM
Corvette Chris
Here's a pic.
http://forums.corvetteforum.com/memb...ettedan22.html
Old Nov 8, 2008 | 03:13 AM
JimiHendrix's Avatar
JimiHendrix
geez....
Originally Posted by Corvette Chris
They should fit.
Old Nov 9, 2008 | 11:14 AM
89corvetteken
The question is do you need spacers
I did a search and came up with no clear answers.
Old Nov 9, 2008 | 12:59 PM
Corvette Chris
I think you're going to want spacers.
Rear wheel (19x10) will be sitting an additional 17mm inboard, and 29mm closer to the shock.
Front (18x8.5) will be sitting an additional 36mm inboard, and 10mm closer to the shock.
This is of course, assuming the cuisinarts are 56mm offset all around (which I'm 99.9% they are), and the C6s are 79mm offset all around. Again, which I'm pretty sure they are.
So yes, they'll fit, but not ideally without spacers.
Old Nov 9, 2008 | 02:25 PM
LD85's Avatar
LD85
Would you need longer studs?
Old Nov 9, 2008 | 02:33 PM
Corvette Chris
Because of the spacers? Depends on the type -- whether its just the slide on over the lug type, or the bolt on type.
I'd think with the over the lug type, it'd be a definite. The bolt ons, from what I've seen, all come with their own studs.
Old Nov 9, 2008 | 05:32 PM
ekess744's Avatar
ekess744
for base c6 wheels, the front wheels will be sitting 13mm in, NOT 36 mm. 3/8 inch spacers in the front and atleast that in the back. Wheel studs will be needed.
Old Nov 9, 2008 | 05:44 PM
Corvette Chris
Thats what I got from the offset calculators. 18x8.5 fronts.
Old Nov 9, 2008 | 05:56 PM
ekess744's Avatar
ekess744
8.5 x 56 mm offset? Thats the same os the c5 base offset which I have on my car. its in but not near as far as you say
Old Nov 9, 2008 | 06:01 PM
Corvette Chris
I entered the offset wrong.
I did think it was a bit extreme.
Old Nov 9, 2008 | 06:02 PM
ekess744's Avatar
ekess744
no problem, just wanted to help the OP out
Old Nov 9, 2008 | 07:18 PM
Orr89rocz's Avatar
Orr89rocz
if you do get C6 wheels try to stick with the 17/18 inch setups. I think the 19 inch looks abit large on C4's.
I have 18/19 on my Irocz and i kinda wish i kept 18's all around but they look good on my car as its not as sleek/narrow looking as a vette.
Old Nov 10, 2008 | 10:49 AM
ekess744's Avatar
ekess744
I'm pretty sure they never made a c6 17 inch wheel from the factory... If you are referring to remolds, I wouldn't do it. They are almost always WAYYYYY heavier and in addition to that, they are often times the same price or more expensive the the real thing. If you want a lightweight/cheap wheel that is 17/18, go with the c5, thin spokes. Can be had for 200-250 a set! C6 take off go for 350-450. Imo, the best wheel if you like the looks is the c5z06. Offsets are perfect, (no spacers need for an 89) and it’s a nice wide rim in the back. I have remolds of the exact same wheel, weighed a sold 10 pounds more I figured they were pounds tops, nope. It is very noticeable seat of the pants on a stockish car. To top it all off, can be had for 500-800 dollars, for a super lightweight wheel. Priceless IMO. Makes the mods go farther!
The only reason that I really see to go with a remold instead of genuine is if you don't want wheels spacers of any kind in the equation, as they often build most wheels in most offsets!
Old Nov 10, 2008 | 11:46 AM
Never Satisfied's Avatar
Never Satisfied
Where's the best place to find a set of OE z06 wheels?
Old Nov 10, 2008 | 11:56 AM
Corvette Chris
Go over to the C5 parts section and look around. If you don't see any, put a WTB post up. Personally, I'd rather see Corvetteken go with the C5 Z wheels. I think they'd look killer with the Charcoal paint on the car
To C6 rims on 89 C4?
Old Nov 10, 2008 | 01:03 PM
LD85's Avatar
LD85
My preference is the thin spoke C5 wheels with the 18x9 and 18x10.5 rears, looks sweet!
Old Nov 10, 2008 | 04:27 PM
ekess744's Avatar
ekess744
ebay or cf parts
Old Nov 10, 2008 | 04:30 PM
ekess744's Avatar
ekess744
c5 thin spokes are 17x8.5 and 18x9.5 OE
C5z06 17x9.5 and 18x10.5 oe
Both are great choices and weigh about the same
