If not test your 02 sensor. Sensor wire connected?
Fuel pressure could be low
Bad Gas
Can't remember but maybe coolant sensor wire can cause code 44
Map Sensor
Just remember to test according to the FSM before you run out and buy parts
Start first by checking for vacuum leaks. Check every line visually. If they're older than 5 years old, just replace them. Hook up a vacuum gauge and post how many inches of vacuum you have at idle.
