Correct Injector Flow Rate for 91
Old Nov 10, 2008 | 05:07 PM
rickso84's Avatar
rickso84
Default Correct Injector Flow Rate for 91
Have a 1991 and seen 21lb., 22lb, and 24lb for flow rates specified for the OEM replacement. What is the correct stock/replacement value?
Old Nov 10, 2008 | 05:21 PM
CaminoSS's Avatar
CaminoSS
Give Jon a shout. He has the sticky about the injectors at the top of the page.
He can get you set up with whatever you want. You will be more than happy about him!
Old Nov 10, 2008 | 10:06 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
the 21 and 22 will work fine without computer refig. the 24 really needs a mod to the ecu program. The OEM is 22.
To Correct Injector Flow Rate for 91
