Build up begins [Pics]
Nov 11, 2008 | 02:20 PM
I'm getting there I just need to send my heads to L.E. for assembly and cam selection.
58mm BBK
Ported LT1 Intake
Stage 2 Ported lt1 Heads
Nov 11, 2008 | 03:46 PM
C4 of Year Finalist (appearance mods) 2019
Did you paint the intake manifold or did you have it powdercoated someplace?
Nov 11, 2008 | 03:52 PM
It was powered coated but it needs to be redone. There is a powder coating place on marine view drive.
Nov 11, 2008 | 05:50 PM
If you dont have emmissions tell Loyd you want a tight LSA. 110 or lower# Good luck!
Nov 11, 2008 | 09:09 PM
Ya know....just a few more bolts and the engine can be turned into a 383
Looks like we're neighbors. I live in Maple Valley, about 40 miles southeast of you
Nov 12, 2008 | 08:49 PM
Quote:
Originally Posted by
96GS#007
I've been toying with buying a short block 383 or 396. Everyone keeps telling me to do it I may bite the bullet and just do it.
What kinda setup for suspension you got?
Nov 12, 2008 | 10:50 PM
St. Jude Donor '05
Do the 383 if you can, youll never go back to a 350 again.
Cost difference is almost nil.
Nov 12, 2008 | 11:23 PM
fc_soldier
'90 Z51 springs & sway bars, Koni adjustable shocks, Global West aluminum del-a-lum bushings in the upper and lower front a-arms, Energy Suspension poly bushings for the front & rear sway bar links and rear camber arms. Other than that, it's stock
