Fuel Pump Question?
Old Jan 13, 2002 | 08:53 PM
CG77VETTE's Avatar
CG77VETTE
Default Fuel Pump Question?
This just started happening and I was wondering if it's possible? It sounds like the fuel pump is still pumping even after the engine is turned off and the key is out of the ignition. I disconnected the battery and the hissing sound stops. Re-connect the battery, starts hissing! What could this be? Thanks in advance for any help. BTW, its an early '86 L98.
Old Jan 13, 2002 | 09:32 PM
Bob Mosaic's Avatar
Bob Mosaic
Default Re: Fuel Pump Question? (CG77VETTE)
CG77,
I am guessing a bad fuel pump relay. This is the most obvious possiblity for the problem. Hope it works out.
Take care,
Robert
:cheers:
Old Jan 13, 2002 | 09:34 PM
Bob Mosaic's Avatar
Bob Mosaic
Chances are the Fuel Pump Relay...Hope it all works out for the better.
Good luck,
Robert
:cheers:
To Fuel Pump Question?
