85 fuel pump in a 84
Old Nov 14, 2008 | 01:32 PM
Jimbo3087's Avatar
Jimbo3087
Default 85 fuel pump in a 84
My fuel pump just went out in the 84 Crossfire.. Heard some people talking about putting a 85 pump in and getting a pressure regulator.. My question is what regulator do I need to make this setup work? The 85 regulator is located on the fuel rail the 84 isn't. Also the 84 is only rated at 13psi the 85 is 13-30 or so psi.. Any advise or does anyone have a regulator that will work?
Old Nov 14, 2008 | 01:36 PM
qws's Avatar
qws
No need to replace the regulator. If you want the 85 pump just go ahead and put it in. There is already a regulator on your rear TB.
Old Nov 14, 2008 | 01:39 PM
Rohn's Avatar
Rohn
There is disagreement on this forum regrding the value of the higher pressure TPI FP. I added it to my stock 84 and could not feel any difference SOP. I replaced a good 84 pump with 70K miles on it with the 85. That allowed me to adequately fuel my future mods planned.
the stock FP reg is mantained. Many will add a FP gauge and set the FP to 13 lbs by modifying the reg to be adjustable. I suspect the stock reg with factory setting may show 12 lbs with either new pump.
I have since replaced the stock reg with an Aeromotive unit.
Old Nov 14, 2008 | 02:10 PM
kehler's Avatar
kehler
no need to do anything, but if you want can modify your regulator and make it adjustable.
Old Nov 14, 2008 | 02:50 PM
Jimbo3087's Avatar
Jimbo3087
Yea but the pumps have a good bit of difference in psi... my mechanic and i looked on his computer and it said max fuel pressure on a 84 pump is 13 psi.. The 85 said some where from 13 and 25 or 30 max psi.. So in that case wouldn't it make a difference if I had it running at 16 maybe 17 psi? and the regulator on a 84 isnt adjustable..
Old Nov 14, 2008 | 02:58 PM
kehler's Avatar
kehler
84 is adjustable, you just need to knock out the plug on the base of the regulator. An 85 pump will definately not hurt an 84. The regulator will knock down the pressure to stock settings if you do nothing and if you chose to make it adjustable you can go up to 14-15 lbs safely.
Old Nov 14, 2008 | 03:08 PM
qws's Avatar
qws
exactly, remember you already have a regulator that will adjust that pressure down to feed your tb's. So the 85 pump won't hurt it at all. Many of us have put in the 85 pump, myself included. My pressure runs at 13 psi with the newer style pump.
Old Nov 14, 2008 | 03:16 PM
Jimbo3087's Avatar
Jimbo3087
cool thanks
Old Nov 14, 2008 | 04:37 PM
85vette-84vette's Avatar
85vette-84vette
What about fuel lines?
84 has rubber fuel lines and the 85 has metal?
Do you need to change the fuel lines with the extra fuel pressure?
Old Nov 14, 2008 | 07:16 PM
Frizlefrak's Avatar
Frizlefrak
Let's clarify a couple of things.
1. Pumps create FLOW...not pressure.
2. Restrictions to flow create pressure.
Think of it this way....if you ran the pressure hose from an 85 pump into a bucket, it would flow at near zero pressure. The restriction the pressure regulator gives is what causes pressure to build.
That said, the regulator on your rear throttle body will limit the pressure to 13 psi max, even with the TPI pump....The 85-91 pump doesn't create enough flow to cause it to go over that.
Now...you will gain ZERO performance on a stock engine over a properly working 84 pump by switching to a later pump. The 85-91 pump is, however, more readily available, and not much more money, if any. It also allows for future mods. When my original pump on my 84 went bad, I went with a 85 pump for that reason.
Your call.
Old Nov 16, 2008 | 11:48 AM
Jimbo3087's Avatar
Jimbo3087
But isn't it simple enough to change the regulator to create more pressure?... Kinda like a in-line fuel regulator...
Old Nov 16, 2008 | 01:03 PM
qws's Avatar
qws
But why waste money for a new fuel regulator if the one on there can already be made to adjust 9-15/16 psi? Just remove the injector tower, turn upside down and remove the housing around the regulator and knock out the center plug. You can put a small notch on the stem of the diaphram and then turn with a small screwdriver. Its now adjustable.
If in the future your going to do more major upgrades then it may be time for a new regulator. With my mods in my sig I'm only running at 13psi.
Old Nov 16, 2008 | 01:20 PM
Jimbo3087's Avatar
Jimbo3087
You wouldnt have any pic in how to do that do yea?
Old Nov 16, 2008 | 01:28 PM
qws's Avatar
qws
I don't.. but it used to be on the old crossfire forum. I just checked in the new tech section but nothing there. Nobody has written it up yet I guess. Check out thirdgen.org in the TBI stickies it may be there.
To 85 fuel pump in a 84
