87 Alternator
Old Nov 14, 2008 | 03:13 PM
fearless's Avatar
fearless
Default 87 Alternator
I just found out my alternator is dead after eating 2 of my batteries. My question is, has anybody put new brushes in one before and would that fix the problem? Is it worth it or should I just go ahead and pay the $100 for a new one?
Old Nov 14, 2008 | 07:23 PM
c4cruiser's Avatar
c4cruiser
Get a good-quality remanufactured alternator. Go with AC Delco or even a Bosch unit. That way you have some sort of warranty with it.
There is no real way of telling if it's just the brushes that have gone bad. Alternators have a built-in regulator and that could be the problem.
Old Nov 14, 2008 | 09:44 PM
jfb's Avatar
jfb
You can take the alternator apart and if its the brushes, you can easily see that that is the problem. Also, some parts stores will test the voltage regulator. Diodes can be tested with an ohmeter. Lowest cost way is to take it to an auto electrical shop and have them rebuild it. Most places do a good job. Ask around. I buy rebuilt AC Delco's and they last a long time.
Old Nov 14, 2008 | 10:02 PM
SunCr's Avatar
SunCr
Instructions on how to rebuild it are here: www.alternatorparts.com
Old Nov 17, 2008 | 08:52 PM
jsinga's Avatar
jsinga
OK, I didn't read the info on rebuilding alternators. The old style SI's are easy to fix. The CS-130 in the 87 is designed as a "throw away". If you have the time you can fix it. It needs more than brushes, it's more than likely the diode bridge and it's soldered in.
My advice; if you replace it ONLY GET ONE WITH A LIFETIME WARRANTY!
Pep Boys replaced mine 3 times! (in 13 years) The last 2 were brand new aftermarket alternators. (They only lifetime new ones now)
Here is what I have found out over the years heat and a weak/low battery is what kills these alternators. If you don't drive it much get a battery tender and you won't have problems. I also replaced the boost fan switch (my 87 has the 2nd fan out front not ECM controled) with a 200 degree switch that helps keep the under hood temps down.
Long ago an auto electric shop told me that generation GM alternator was good for about 85k miles, or 4yrs in front drive and cars without an engine driven fan.
JS
Old Nov 17, 2008 | 09:25 PM
Joe C's Avatar
Joe C
JS
the alternator went out on my 90 last week, and i purchased a new "lifetime warranty" assembly from autozone for $125. no muss - no fuss - back on the road within hours...
To 87 Alternator
