Do we have two filters?
Old Jan 14, 2002 | 11:22 AM
Jsailor24's Avatar
Jsailor24
Default Do we have two filters?
My car started acting like it was starving again only running at throttle so i replaced the fuel filter again which was the cure last time thinking there might be crap in the tank-- old one was pretty clean. Do we have a 2nd filter before it enters the fuel rail?
Old Jan 14, 2002 | 11:28 AM
scorp508's Avatar
scorp508
The 2nd filter is a return line filter.
Old Jan 14, 2002 | 11:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Do we have two filters? (Jsailor24)
There is also a pickup screen on the bottom of the fuel pump inside the tank.
Put a pressure gauge on the Schraeder valve on the fuel rail so you can see how the pressure is behaving. If it has a 2-3 foot hose you can lay the gauge on the windshield (under the wiper arm) to monitor fuel pressure as you test drive.
To Do we have two filters?
