LT4 Rocker Arm Recall
cut and pasted from : http://www.hashmarks.com/techtips/rockerarmrecall.htm
The early LT-4 engines had 2 roller rocker arm recalls. They were due to "improper loading" on a pin that retains the roller section and it could back out under high RPM. In the second recall the first replacement rockers part #12551311 were also recalled. The second and final rockers part #12557779 were used check with your dealer if your car falls within these numbers. The 1.6 aluminum roller rockers were manufactured by Crane for GM. For the aftermarket these rockers are advertised as the Crane Gold units.
The first recall (recall number 96-C-07) involved these VINs:
Regular production From: 5100052 through 5102717
Grand Sports From: 5600013 through 5600055
The second recall (recall number 96-C-07A) was extended through these VINs:
Regular production From: 5100052 thru 5111116
Grand Sports From: 5600012 thru 5600363
So if your Corvette's VIN does not fall within these ranges, you shouldn't worry about the rocker arm recall action.
Just to be sure, however, any GM dealer should be able to give you a warranty repair history of your Corvette if you supply them the VIN. Some dealers charge for this service, however.
They cannot tell you what *has* been done, but they will tell you if recall work has *not* been and needs to be done.
