TPS Voltage Setting
already....just had a "arctic Blond" moment. I realize that I need the change on the e-prom but it ran great since I got her last year and then WHAM late Aug. this year the problem started. ..both at cold and hot. Like I stated previously; once the timing was changed it ran great hot and when cold it would intermittenly do it cold but ever so slightly but would clear within a few seconds and when I played with the TPS it was fine ..no intermittent at .58 but almost coming back at .56. In the spring I will bump up the timing and I need to do a mandated emission test and can compare the data to when the seller had to do a mandated emmission test to sell...here in Ontario,Canada they are strict like California. I feel confident that the reasoning to bump the timing up will cure the problem and if the emission test is not good; I will have to reprogram.Thanks for your insight as I want to really get into these areas more now as Im retired and have more time to devote to my hobby.
I say again...DAMN!!! thought I got back in time to edit...You Got Me!!!
Wish I could be more help with that. But your symptoms lead me to post about it, especially the rich condition. Mick could probably explain this better, but you don't have a cold start injector, that ended in 89. So, the CTS sends it's signal to the ECM, which compensates the AFR, low temps, it adds more fuel, if it's intermittent or bad, (voltage not dropping properly) you'll have a rich condition. Like any intermittent their hard to catch.
Thanks again to all that replied!!!!
My thoughts were because the 727/730 ecm's prportional fuel control uses 2 tables for basic fueling in Open Loop (aside from pulse width, battery voltage etc.). Both of these are based on 'look up' from coolant temp., to deliver an added amount of fuel for various temps. Colder temps -40c will have the most amount of fuel added to net approx. 10.1 afr as it heads toward 90c it begins to taper down (less fuel added). If the CTS were funked up, and let's say continued (regardless of real motor temp) to give a lower reading to the ecm, than real operating temp., it could be giving a motor that is operating @120* the same fueling that was being added at say 40c. (we are only talking about Open Loop, colder or cold weather start/running). Compounded with interminttent failure, the car would still be going into closed loop, and not just stuck in open loop, and yet doing funky things on warm up. This is what Rick is referring to.
I don't have my FSM here in front of me now, but I know they have it measured and tested w/ohm readings. I don't usually use a vohm anymore, every time my car is running I have the laptop on, w/a scan program tts or the like, and just watch the operation of all sensors. When they are looking sluggish to that point etc.I usually swap them out. I have watched bad 02's this way that wouldn't barely move let alone go over the cross over, and throw the tune rich, etc. etc........and never throw a code, maybe I didn't wait long enough
....yeah it's possible. As I mentioned earlier, I would be looking all of it over.....
did I mention change the injector constant for that to 24# so you can put the fuel pressure back to were it should be ?...don't remember
