Replace the Optispark?
Old Nov 20, 2008 | 01:25 PM
markjonesa's Avatar
markjonesa
Default Replace the Optispark?
Replacing the water pump on my 1993 with 60K miles. (I've owned it for 2 years) Mechanic says replace the Optispark while the water pump is off because it's probably the original Opti and it's cheaper to do it now.
What do you think??
Mark
Old Nov 20, 2008 | 01:31 PM
cbryant's Avatar
cbryant
atleast remove it and check the bearings. Definitely replace the cap and rotor
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If you do, make sure YOU supply the Opti, though, not the mechanic. I'll bet you can get it at least $100 cheaper than his quote.
Definitely replace the cap and rotor.
It wouldn't be a bad idea to inspect the timing cover seal for oil leaks, either.
I'd replace the plugs and wires, wire holders, and looms, too, since you'll never have better access to 'em than now.
Old Nov 20, 2008 | 02:33 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Be prepaired to get bent over- this is a super-sucky job.
To Replace the Optispark?
