Whoops.
Old Jan 15, 2002 | 12:36 AM
Mnemonic63's Avatar
Mnemonic63
Default Whoops.
Hey all, i have had a prob with my heat. it goes on for a minute and then goes cold. i beleive now that it is my heater control valve... but could be a vacuum problem as well.
when i went to go manually open the valve,i broke the hose on the top of the valve... thing is, the heat still does the same thing and i dont hear any air out of the broken hose....
i dunno what to do. plz help :-)
-Dan
Old Jan 15, 2002 | 08:39 AM
89 Bob L's Avatar
89 Bob L
Default Re: Whoops. (Mnemonic63)
We need more info. What year is the car, how many miles, and is it automatic climate control? It could be nothing more than a bad vacum tee ( near the distributor or a bad programmer. More info please.
Old Jan 15, 2002 | 08:57 AM
Mnemonic63's Avatar
Mnemonic63
Default Re: Whoops. (89 Bob L)
its an 84, manual heat , and it has 72000 miles
Old Jan 15, 2002 | 09:38 AM
Corvette0096's Avatar
Corvette0096
If the heat goes away when you are at an idle and comes back on when you accelerate you don't have enough water in the radiator
Old Jan 15, 2002 | 09:45 AM
JonM's Avatar
JonM
Did you break the hose or the metal part the hose fits over? If you broke the metal part the replacement # is 14046043. You shouldn't feel air coming out of that hose, its a vaccum hose. With the heat turned on that valve should remain in the up. If it does, and the heat still on, feel the hose both going in and coming out. They should be hot. If the top one isn't hot that valve is bad. To check it, remove it and blow into one end and manually move the valve. If the bottom hose isn't hot, you most likely have a clogged core.
Old Jan 15, 2002 | 10:43 AM
Mnemonic63's Avatar
Mnemonic63
Default Re: Whoops. (JonM)
last time i felt the hoses i beleive the bottom one is hot.... i want to try opening the valve manually, but i dont see this little lever you guys are talking about, all i see is a hard plastic hose going into the metal valve. is it on the bottom of the valve?
-Dan
Old Jan 15, 2002 | 02:40 PM
JonM's Avatar
JonM
Yes it pushes up from the bottom, the arm is attached to a plate and the arm has an elbo. When the heat is on the arm pushes up on the shaft. If both hoses are hot then the valve is most likely working. Are you getting air through your duct work in both AC and heat? There is a vaccum door in the duct work that seperates the two. Perhaps the one for the heat isn't working. You have to crawl under the dash on the pass side to check it out.
Old Jan 15, 2002 | 02:47 PM
Mnemonic63's Avatar
Mnemonic63
yes, i have checked the door and heat and A/C both work...and as i was saying to the best of my knowlege the top hose is not hot and the bottom hose is... ill test it out when i get home :-)
To Whoops.
