Engine Ping Problem, Help!
Old Nov 22, 2008 | 06:26 PM
ride250s's Avatar
ride250s
Default Engine Ping Problem, Help!
1987 Corvette Z52 with a 4+3 and 76,000 Miles.
So I get this engine ping only under heavy throttle, and only when the engine temp is above 190 degrees. A few weeks ago I had the chevy dealership diagnose the problem and they said it was a bad EGR. Well I finally got around to replacing the EGR today.
It still pings...
The engine runs absolutly perfect otherwise. It has good idle, and great throttle response. The ping sounds like a big rattle coming from the engine compartment and will happen somewhere in the middle of the powerband, and when it stops higher in the powerband i feel noticibly more power. The ping must be causing the engine to retard.
Has anyone had this problem? Could anyone help me diagnose this problem? The vette is just no fun to drive if you can't ever get on it...
Old Nov 22, 2008 | 07:10 PM
ride250s's Avatar
ride250s
I should mention that I run 93 Octane.
I have been searching some posts and it seems to be somewhat common for L98's. I am going to try some top engine cleaner tomorrow. I just wish this problem would go away haha.
guido7834's Avatar
guido7834
I had same problem with my 87. Timing was too advanced, I would check that first.
Old Nov 22, 2008 | 07:14 PM
floridamale's Avatar
floridamale
Make sure to check your knock sensor the conector may have come loose or it may be bad. It's just in front of your starter.
Old Nov 22, 2008 | 07:22 PM
ride250s's Avatar
ride250s
What was it set at?
Old Nov 22, 2008 | 09:01 PM
rodj's Avatar
rodj
As soon as the ECM sees a signal from the knock sensor it pulls timing out at a rate /time period as set in the calibration on the memcal.
Check timing is at factory 6 degrees before checking anything else.
If KC is faulty or disconnected car will run like #@%& across the range and throw a code.
Old Nov 22, 2008 | 10:02 PM
rick lambert's Avatar
rick lambert
Just my opinion, but if it were the knock sensor you wouldn't, I don't think feel that power in the higher RPMs, simply because if the KS detects knocks it will retard timing, and if it does that you won't feel increased performance. Another thing is the octane you're running........doesn't do a damn thing for your 87, 87s were (or I should say required at the time) to run 87 octane! Per my 87 owners manual! Base timing is a good thing to check, original base for an 87 was 6*, mine runs better at 8*. I do use SeaFoam once a yr. and that helps clear carbon (which can cause pinging or knocking,removes condensation in the tank) and also helps keep the fuel system clean.
Old Nov 22, 2008 | 10:13 PM
mjb1019's Avatar
mjb1019
Had the exact same thing on my 87 two weeks ago. The timing was corrected and no problem now.
Old Nov 23, 2008 | 07:56 AM
guido7834's Avatar
guido7834
I agree with the seafoam, but regardless of what octane WAS required, at this time my car would ping terribly worse with lower octane fuel until the timing was corrected, Must say something about the crappy quality of gas today?
Old Nov 23, 2008 | 11:07 AM
rick lambert
One other thing. You said the problem was diagnosed as an EGR, and you replaced that, well, 95% of the time when a EGR code is thrown it usually is the EGR switch, cheap part, not the EGR itself. So watch for an EGR code to re-surface, and mine was an intermittent.
Old Nov 23, 2008 | 01:10 PM
ride250s's Avatar
ride250s
From what I can tell, most of the additional EGR components are discontinued... Solenoid, switch, temp sensor... I had a hard enough time getting the corect EGR. I ordered it 3 times through the local parts store and the correct part number came but evertime the EGR wasn't correct, had a different base. Finally the right one in the same box and part number as the others came in.
Old Nov 23, 2008 | 06:27 PM
ride250s's Avatar
ride250s
*Update*
I checked out my timing and it was advanced off the tab... So I set it at about 7 degrees, and it doesn't ping anymore!!
However, the car doesn't seem to be as fast... It runs great and all but it seemed quicker before I changed the timing.
What would be an optimal timing setting where my engine would be just as quick and not ping?
Old Nov 24, 2008 | 10:41 AM
rick lambert
Try 10*,
Old Nov 24, 2008 | 01:57 PM
ride250s's Avatar
ride250s
I just ran some gm top engine cleaner through it, and I got a lot of smoke, but not out of the tail pipe! I think it was coming from an emissions tube on the passenger side exhaust manifold. Is this bad?
Old Nov 24, 2008 | 06:13 PM
zr1clone's Avatar
zr1clone
I am going through this same thing right now! This is driving me nuts! My 1990 does the same thing at mid range throttle...bogging down then at 3/4 to full throttle... BAM the power comes back. I have a KS code and an EGR code. Can I just disconnect the KS or put in a resistor? I hope we can get to the bottem of this. ZR1clone
Old Nov 24, 2008 | 06:57 PM
ride250s's Avatar
ride250s
Well, I replaced my EGR and that did nothing, but then I cecked my timing and it was way off. I set it to 7* and no more ping/knock! I just have to mess around with setting the timing at different spots to try and get a little more power while still having no ping.
So check your timing!
To Engine Ping Problem, Help!
