MAF or SD
Old Jan 15, 2002 | 09:26 AM
MrJay's Avatar
MrJay
Default MAF or SD
How can I tell if I have MAF or SD?
I have a TPI that came of my 68 Camaro but I dont what kind it is, it does not have the MAF, so I was wondering if it was a SD unit, but then again since the people that had the car befor could not get it started and now Im thinking maybe it is a MAF unit and they just did not have it on.
Jay
Old Jan 15, 2002 | 09:51 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: MAF or SD (MrJay)
if it was speed density, the plenum will be drilled for the MAP sensor on the passenger side, just above the FPR on the side of the plenum.
Old Jan 15, 2002 | 10:04 AM
MrJay's Avatar
MrJay
Thanks Craig
what is the FPR?
Jay
PS Craig if I take off the cats will I have to get a nother chip?
Old Jan 15, 2002 | 10:25 AM
Marcho Polo
Former Moderator
FPR = Fuel Pressure Regulator
Here's a picture of the MAP sensor location:
about the cats.... if you mentioned to me before that you might be removing them, I probably removed the code 32 check.... I don't remember right now. I can check your setup when I get home.
Old Jan 15, 2002 | 12:37 PM
Red91C4's Avatar
Red91C4
Default Re: MAF or SD (Marcho Polo)
Speed desity or Mass Air flow is determined by which ECM you use.
Monte
Old Jan 15, 2002 | 12:47 PM
MrJay's Avatar
MrJay
Thanks guys I will have to check it when I get home.
Craig you are the man!
Jay
[Modified by MrJay, 7:17 AM 1/16/2002]
To MAF or SD
