LT1 electric water pump question
I know the hole in the timing cover has to be pluged. I'm told a 1.25" freeze plug fits perfectly.
What I haven't been able to find out is, if I have to plug the hole in the block where the pump driveshaft bearing would normally set. That's the one through the web between the valve lifter gallery and the timing chain area. If so, what with?
BTW! My engine is on an engine stand, not in the car. So at this point I can do about anything with relative ease.
Rick
PS:If that concerned about it, just press off the shaft bearing and reinstall it back in the block.I chose to epoxy mesh screen in this hole and all others draining back to the pan should any valve train parts decide to break. This would help capture any broken pieces. Just some food for thought. It really just depends on how far you want to go with the build.
