Mini ram users
Old Nov 27, 2008 | 08:36 PM
Movnviolation's Avatar
Movnviolation
Default Mini ram users
I just mounted my Mini Ram. How many of you eliminated the coolant from running through the Throttle body and cut the water cavity off of the lower throttle body. If so how did you do it? Can I just eliminate the coolant and not cut the lower throttle body? Hate to butcher a part!
Opinions please!
Old Nov 27, 2008 | 09:11 PM
mseven's Avatar
mseven
don't hava a pic handy but I had to cut that part of the IAC housing off to clear the water housing.
Old Nov 27, 2008 | 09:16 PM
JackDidley's Avatar
JackDidley
Me too. No biggee. I think I used a air cut off tool. Went to the auto parts and they let me go in the back and pick a formed hose to hook to the metal heater line.
Old Nov 28, 2008 | 05:50 PM
pipe's Avatar
pipe
Same here the bottom of the TB will rub the Thermostat housing if you don't remove the water cavity off the bottom of the TB. I think TPIS has a pic on it's website of where to make the cut. If ya don't want to cut up yours look on the parts board and see if someone is selling a stock TB and steal it off that onePipe
Old Nov 28, 2008 | 05:56 PM
cwyates4's Avatar
cwyates4
hmm...I'll have to go outside and check that out...my TB is a holley, so I have no clue what had to be done to make it fit.
To Mini ram users
