Tire wear
Old Jan 15, 2002 | 04:16 PM
Lars1992's Avatar
Lars1992
Navigator
Default Tire wear
I am wondering if anyone can shed some light on tire OD size as it relates to replacing one tire per common axle instead of two at a time as recommended? If you have a tire that has 50% tread left, and you have to buy a new tire to place opposite of the older tire, will the difference in OD cause a maintenance problem such as wheel bearing failure? My 92 has a rear wheel bearing with .007" play when you rock the wheel from top to bottom.
Thanks for any help I can get on this topic.
