I wanted to thank all for the kind words. I will get a sound clip and post it soon. Today we are haveing some sleet up here so it will probably be next weekend
Any pics of underneath showing how the pipes are routed?
Short block hugger headers, 90 out to a 45 into the side pipe. The side pipe inlet is right behind the wheel well, like it was made for it. I don't know if some long tube headers would work.
Right now its on with some crush bent tube. Not a big fan of wrinkled pipe but I have some 2 1/2 stainless pipe that I can replace it with later. Right now its just a matter of getting it on and not leaking.
If it stops raining long enough I will try and snap some pictures.
While it was up on the stands for the sidepipes I pulled the 1-2 servo to have my shift feel tweaked, raised my ride height back to stock after the engine lowered it for me,put the derale pan on (thanks weav), and refilled with synthetic. Hopefully that will help my tranny temps under power.
Here are a couple of pics that I took on the test run.
I must admit that I like ride with the height back up there, I love the lowered look but it is much smoother now
The pipes are different. Did you build that hood or buy it?
Just molded(not very well I might add) an ebay L88 scoop on there. I wanted to go with a stinger but needed 3.5" to clear the air cleaner that I went with.
