Roll bar w/swing out bar
Old Nov 29, 2008 | 04:20 PM
JOHN89's Avatar
JOHN89
Default Roll bar w/swing out bar
It's finally finished!
Old Nov 29, 2008 | 05:40 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Where did you mount it in the foot well area? Pics?
Old Nov 29, 2008 | 05:55 PM
Beach Bum's Avatar
Beach Bum
Looks Great !
Resembles my S&W rollbar..... same pin for the swing-out as well.
Old Nov 29, 2008 | 06:18 PM
JOHN89's Avatar
JOHN89
I welded it to the the rocker panel inside via the square floor plates provided with the roll bar kit. Unfortunately I didn't take any photos of it yet. It did take a little fabricating to get it accomplished.
John
Old Nov 29, 2008 | 06:25 PM
JOHN89's Avatar
JOHN89
Originally Posted by Beach Bum
Looks Great !
Good eye Beach! Correct! It is an S&W 8 point roll bar kit with double swing out bars. I modified the rear down bars so that I can continue to remove and store my roof in the back factory storage area. I have configured it as a 5 point (drivers down bar only) which is good for 10.00. I don't have any desire to go below that with this car.
Cheers,
John
Old Nov 29, 2008 | 07:41 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice!
Old Nov 29, 2008 | 10:19 PM
pipe's Avatar
pipe
Cool lookin job S&W is just a few miles down the road from me!Pipe
Old Dec 1, 2008 | 11:58 AM
redrose's Avatar
redrose
shoulder strap mount points are too low...expect a busted collar bone (or two) if you use 'em as is and crash...correct shoulder strap install only prevents upper torso forward motion by restraint across sternum (breastbone) area, does NOT attempt to restrain vertical motion (lap belt does that IF mounted properly).
Old Dec 1, 2008 | 02:52 PM
slickfx3's Avatar
slickfx3
did it stiffen the chasis?
more than an vert x bar?
Old Dec 1, 2008 | 08:01 PM
JOHN89's Avatar
JOHN89
Hmmm...I mounted them per the instructions from G-Force. They state shoulder harness should not be more than 1-4" below shoulder height. They are above the top of my shoulders when I sit in the seat by atleast 1"-2".
So how high above my shoulder should they be? Anyone else think they are too low? How about some pictures of yours?
John
Old Dec 1, 2008 | 08:04 PM
JOHN89's Avatar
JOHN89
I am not familiar with the vert X bar. The 4 point in the back stiffened it alot. You can't really tell until you remove the roof. There is no more flex with the roof removed.
John
Old Dec 3, 2008 | 10:27 AM
Vic'89's Avatar
Vic'89
Is this the Chrome Moly or Steel kit ? Do you know the weight ?
Vic
Old Dec 3, 2008 | 11:44 AM
JOHN89's Avatar
JOHN89
Vic
It's the steel kit. I never weighed it. It can't be much because I modified it quite bit. The main hoop is shortened. The rear down bars are short. I only installed 5 points. The kit is actually an 8 point.
I would say less than 100lbs.
John
To Roll bar w/swing out bar
