85 Fuel Pressure ?
Old Nov 29, 2008 | 10:04 PM
presasa's Avatar
presasa
Default 85 Fuel Pressure ?
I checked the fuel pressure on my 85 today and it has 35psi; the car runs great - but I thought it needs to be around 40 -45psi. What is the norm - the cars has 70K miles
thanks
Old Nov 29, 2008 | 10:16 PM
l98tpi's Avatar
l98tpi
Max G’s
Default 85 fuel pressure
A publication I have says that GM recommended fuel pressure for 1985 model year is between 34-40psi. If your car is mainly stock and you have an adjustable fuel pressure regulator, try 42psi.
Old Nov 29, 2008 | 11:11 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
thanks
the 85 has a recommended rail pressure of 36psi. this is why the 85 uses a 24lb fuel injector. in 86 the regulator was changed and the running rail pressure was increased to 43.5psi to increase atomization of the fuel. At the same time the injector size was reduced to 22lb. If you increase fuel pressure to 43 in a 85 you will have close to a 26lb injector. The engine will run fine but your engine will be rich in open loop and be real fat at WOT
Old Nov 30, 2008 | 12:31 PM
presasa's Avatar
presasa
thank you all for the info - I have done some mods to the car;I.E. Headman Headers, true dual exhaust with flow master mufflers, K&N air filter and a Hypertech chip. the car runs great. I will probably leave the fuel setting alone for now. What do you all think on a larger mm throttle body? Recommendations???
Old Nov 30, 2008 | 06:25 PM
powerpigz-51's Avatar
powerpigz-51
I'm running 19# Ford yellow tops in my 85 with some mild mods...I'm at 43 pounds, does anybody think I should be higher? (at wot)
Old Nov 30, 2008 | 06:35 PM
FICINJECTORS
Supporting Vendor
The yellow top ford/bosch is at almost 22lbs at 43.5 which is about equal to the stock 24 at 36psi. I don't think a mild modded 85 will need much more. Read the plugs and see if you are lean after some heavy driving, if the plugs read good, you are ok
Old Nov 30, 2008 | 06:58 PM
l98tpi's Avatar
l98tpi
Max G’s
Default tb upgrade
With all the upgrades you've performed on the exhaust side, you could use some more intake air. Unless you change the inake with larger runners and ported plenum, a larger tb will probably not give you any gain. If you do upgrade your intake a 52mm tb will work very nice.
Old Nov 30, 2008 | 08:01 PM
presasa's Avatar
presasa
thank you again everyone this is usefull information. the last thing i am trying to fix is the over-drive on the 4 + 3. it was working fine and recently it stopped going into overdrive. the microswitch on the shifter is good and the oil and filter is also new. any help on this?
Old Dec 31, 2008 | 09:25 AM
1982CorvetteDude's Avatar
1982CorvetteDude
Here's a bump for you
I wanted to ask a injector question for these other guys
My 82 has a TPI set-up in it. I have a custom chip set for 22# injectors, but I don't remember what year corvette my fuel rail assembly came off of....it was either 85 or 86.
My injectors are stock Corvette injectors, is there a part number on them that will tell me if they are 22 or 24 lbs?
Thanks!!
To 85 Fuel Pressure ?
