1996 Wheels
Old Nov 30, 2008 | 10:21 PM
jsls0130's Avatar
jsls0130
Default 1996 Wheels
I'm going to buy me a new set of rims for my 1996 CE Corvette and was wondering if I can use 9.5 width on the front and back wheels or do I still need to use 8.5 on the front? Thanks in advance, John.
Old Nov 30, 2008 | 10:38 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, you can use 9.5 front and back if you want.
Some Corvettes came stock with the 9.5 on front.
With the 9.5 front wheel, you might want to consider running a different tire than came with the 8.5 wheel.
Front 8.5 wheel = 255/45-17 tire
Rear 9.5 wheel = 285/40-17 tire
All 4 9.5 wheels = 275/40-17 tires
You can keep your factory 255/45 tire, but it will look a little funny (bulged out at the bead) on the wider wheel. I believe it is still within the recommended range though. But it does look funny.
Old Nov 30, 2008 | 10:47 PM
jsls0130's Avatar
jsls0130
Thanks, John.
Old Dec 1, 2008 | 05:05 AM
Weav's Vet's Avatar
Weav's Vet
I have 9.5 on all four corners on my '96. I'm running 285/40/17. I did this so I could rotate the tires. You will find it is a little more sensitive to road ruts with the wider tires on front but on a street car that's about the only problem you should have.
Old Dec 1, 2008 | 09:11 AM
JAKE's Avatar
JAKE
Yes, you can run 9.5s at all four corners; that's what my son has on his 96.
On my 96, I just installed 9.5s in the front and 10.5s in the rear. I'll be moving to new tires soon, but right now I'm using 40s in the front and 35s out back. No clearance issues.
Right away I noticed having 1" wider wheels out back makes the car feel like it's on rails. Much more stable.
Jake
To 1996 Wheels
