headlight help!
Old Dec 3, 2008 | 12:03 PM
cwyates4's Avatar
cwyates4
Default headlight help!
Well, my luck. My '85 doesn't have '85 headlight motors! I had already bought the gears for the '84-'87s...now I see that I need the bushings for the 88-96.
Question, does lowes carry them? If so, part number? Thanks!
Old Dec 3, 2008 | 02:55 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't know about Lowe's but Home Depot does. I understand the part number changed, so maybe someone else has the new number?
Old Dec 3, 2008 | 04:30 PM
cwyates4's Avatar
cwyates4
eh, nevermind. I ordered all new bushings and gears for it. The gear was in pretty bad shape too, and the bushings were just powder.
Wonder why my '85 has the newer style headlights?
Anybody need some gears for the 84-87s? I've got a set that'll I'll let go for $20.
Old Dec 3, 2008 | 06:57 PM
neversatisfied12's Avatar
neversatisfied12
Do you have both sets?
Old Dec 4, 2008 | 08:27 AM
onedef92's Avatar
onedef92
The previous owner probably decided to retrofit it with the improved headlight motors in the 1988-96 models. With the exception of the Delrin bushings, they're generally more reliable than the first-gen units.
Old Dec 4, 2008 | 09:30 AM
cwyates4's Avatar
cwyates4
Your probably right. Along with that, he dropped in a 500hp engine, built transmission, rearend gears, a driveshaft safety loop, and the newer support system for the hood. I'm glad and mad.
Nope, I've got both gears for one side.
On a side note, these things are pretty easy to rebuild!
To headlight help!
