Intermittent problem...?
Old Dec 3, 2008 | 12:20 PM
95wht6spd's Avatar
95wht6spd
Default Intermittent problem...?
Car just started acting up 2 days ago.
Fine most of the time, then sounds like it misses or kind of a fluttering or resonance type sound from exhaust. Seems to do it mostly, or all at lower RPM's, mostly around 2k. Sounds louder and runs a little rough/jerky. It is not constant, comes and goes. Seems to do it more after I have sat at idle at a light etc. But if I give it some gas when it acts up, it powers right through it and then doesn't show any problem until cruising around again. Idles fine.
Ideas, things to check?
Old Dec 3, 2008 | 01:39 PM
mseven's Avatar
mseven
I would run datamaster and see what's happening .....ideas, fueling (pump, filter, reg.) ? ignition ? battery/alt. voltage ?, guess I'd start by looking in all the normal places.
Old Dec 3, 2008 | 02:02 PM
runner140*'s Avatar
runner140*
Pull the codes. Sometimes you get lucky. Get back to us.
Old Dec 3, 2008 | 02:55 PM
nysec's Avatar
nysec
I was having similar problem with my 91 L98 forum member suggested I check injectors. found 2 bad ones. Called Jon @ Fuel Injector Connection 770-888-1662 ordered new injectors after installing them problem corrected.
Old Dec 3, 2008 | 10:55 PM
95wht6spd's Avatar
95wht6spd
Maybe, but these are only 2 years old.
I added some gas today, will see if that helps, maybe bad gas.
Old Dec 5, 2008 | 06:22 PM
95wht6spd's Avatar
95wht6spd
It was the O2 sensors. The problem became worse and I suspected these because I had them go out before. I didn't think it was the problem at first because had them replaced only 2.5-3 years ago. Plus have the heads/cam now and it is rougher and smells of fuel anyway.
Old Dec 6, 2008 | 09:22 AM
WW7's Avatar
WW7
Thanks for getting back to us and letting us know what the problem was. Wish more people did this..WW
To Intermittent problem...?
