Datamaster variables
Old Dec 4, 2008 | 02:54 PM
simple green's Avatar
simple green
Default Datamaster variables
Hey Gents,
I'm trying to use the Datamaster Dyno and 1/4 mile calculator. Does anyone know the front surface area drag coefficient, the drivetrain loss and tire revolutions per mile? I'm running 40 series on 17" my car is a 94 LT1 6spd.
Chu
Eric
Old Dec 4, 2008 | 03:00 PM
simple green
Also, I think my rearend is a 3.36 does that sound right? and if anyone knows off hand what my 2nd + 3rd gear trans ratios are it would help.
I've just completed a blowerworks install and will post the gain results
E.
Old Dec 4, 2008 | 04:14 PM
rodj's Avatar
rodj
Gear ratios - 1st-2.68, 2nd-1.80, 3rd-1.29, 4th-1.0, 5th-0.75, 6th-0.50, Reverse-2.50
Most allow 15%
Drag coefficient .34
(http://auto.howstuffworks.com/1984-corvette2.htm)
Old Dec 4, 2008 | 04:19 PM
Aurora40's Avatar
Aurora40
The tire revs per mile, you can look at the specs from the tiremaker for your tire. I seem to recall reading the frontal area is around 19.5 sq. ft?
Old Dec 4, 2008 | 06:55 PM
JackDidley's Avatar
JackDidley
I cant answer your questions but I can say the Datamaster time to distance calculator is very accurate. Always within a couple hundreths of what I run at the track.
Old Dec 4, 2008 | 07:04 PM
simple green
Great thanks all,
For future use I found this for revs per mile calculator http://www.gordon-glasgow.org/tirecalc.html
results to follow
Old Dec 4, 2008 | 07:13 PM
STL94LT1's Avatar
STL94LT1
Nope, all 94 M6 Vettes had 3.45 gears.
Old Dec 4, 2008 | 09:50 PM
simple green
Default results? What do you guys think?
My best 1/4 mile was 12.88 that's with no preburnout. And I'm having traction problems through 2nd gear
Anyways the datamaster is saying
321hp @ 5228 w/ 405ft/lbs @4165 stock
516hp @ 5228 w/ 523ft/lbs @ 5074 8psi boost w/ methanol injection
To Datamaster variables
