Very interesting discussion, I've been using a 30/70 mixture of Prestone Green and Redline Water Wetter with Distilled water in my Vette with no problems but maybe I'll have to look at other options. There has been alot of coolant discussion on some of the diesel forums and based on some good information being shared there I changed the green Ethylene Glycol coolant in my `01 Ford 7.3L Powerstroke to the Chevron Delo ELC Coolant a few years and lots of miles ago and it has worked great for me. I'm wondering if that coolant would work in a Vette?
The Chevron Delo Extended Life Coolant is made to fit the new spec of many large truck and offroad heavy equipment manufacturers like Detriot Diesel, Cummins, Komatsu and Volvo. It is a nitride-free OAT type coolant. This means it uses the same basic coolant technology as Dex-Cool. Texaco also makes a new nitride free OAT type coolant that meets the same spec.
I'm not sure if it would work well in your vette, being an OAT type coolant like Dex-Cool I probably would not use it!
forgot to mention Zerex. This is another crap all car makers should make this standard. Just like the airfoil, all coolants guarantee to cool your engine better but we already know the answer to it.
Use GO5 or HOAT coolant. I bought mine from a Chrysler dealer dyed bright orange. It has long life and extended corrosion protection being a modern technology coolant without all the potential problems of OAT type (Dex-Cool and Dex-Cool Clones) coolants.
Or you could continue to use the factory fill Orange Dex-Cool it came with, just be sure to change it every two years, not the five year interval, GM suggests for it!
I used distilled water in my vehicles, particularly the aluminum-radiatored ones, for decades.
Then I read a chemist's experiment that showed distilled to be less stable in a cooling system environment. Lacking its own minerals, the water would leach minute amounts from metal components it contacted. Until the water could remineralize itself and become stable, metal was being removed or eaten away, at a molecular level.
I think most people don't keep or drive their vehicles long enough for the type of water to make any noticeable difference anyway.
If you mean right on about draining the coolant for winter storage I would have to strongly disagree. Reguardless of the real or imagined degrading effects any coolant may or may not have on seals, gaskets, or hoses the internal corrosion that would occur inside your engine block, heads and radiator would certainly outweigh the thought of trying to save those seals and gaskets by draining your coolant for winter storage. Seals gaskets, and hoses can be more easily replaced than your entire block or heads, or even the radiator!
Disagree-
Just go with marine products. My 1977 -454 is cooled by lake water and stored dry. No problems. I have seen one set of head gaskets for a car engine that was put in a boat and after a year the gaskets were eaten up.
You could use the Amsoil coolant, they are not the only manufacturer making a propylene glycol coolant. It's not really a high performance coolant but has the advantange of being non-toxic and bio-degradable as are all propylene glycol coolants. However be aware that your cooling system was designed to use an ethyene glycol type coolant, as all of the coolants discussed in this thread so far are. Some cooling system components in our C4's may not be compatible with propylene gylcol coolant???
Because I may be more knowlegable than some, when it comes to coolants does not make me an expert, nor do I claim to be one!
My posts are from the been there, done that, variety no different than the knowlegable poster who may be posting on brakes or heads as they relate to C4 applications. My coolant choices are based upon previous mistakes I have made, (as I'm sure have many others) specifically with Dex-Cool, that upon detailed research I can recommend a better coolant for our C4's. Do as you please it is after all your Corvette, not mine. But you have been warned!
Disagree-
What marine products are you recommending??
Are you saying your running a 454 cu inch V8 that cools itself with lake water? Is the block iron or aluminum. Don't you mean instead of an air too liquid radiator your running a liquid to liquid intercooler that uses lake water to cool the block ~ You still would need some type of coolant running thru the engine to do this? Right??
But, I'll leave it up to the experts like Mako41 as to whether it would be suitable for your C4s or not.
I WOULD RECOMMEND EXTREME CAUTION in using a PROPYLENE Glycol anti-freeze in an older car (e.g. our c4's). Reason is that propylene can have a very detrimental effect on many types of rubber and possibly other materials too (e.g. a boat's sea-water rubber impeller will degrade to unusable in just the few North East winter months when used to winterize the cooling system).
BTW, Texaco brand anti-freeze is also the 'old style' green anti-freeze (ethlyene Glycol with silicates, not sure if it also has potassium though).
I'm getting ready to flush my system. Wondering how much does it hold. Burbing is easy just park the tail of the vette on about a 20 degree down angle start it up add your fluid and watch to bubbles.
Just drained and refilled my 96 LT4...Dex-Cool...The stuff that was in there appeared to original...looked like new...but 12 yrs old. I stayed with the original type antifreeze because I am a University of Texas fan...and its Orange...that is a legit reason if you're from Texas.
I've had my '92 for going on 2 yrs now, and my daily driver is a 67 ford Galaxie. The 92 was over-maintained @ 41,610 miles when I bought it, and just turned 60k. Have I missed the service interval for the cooling system?
And how true is the 'refill it on an incline' story? I'm all about easy. If I blow this motor up, I'll get it right the next time.
I just did my Impala LT1 motor, and all the sudden, the water pump gaskets start to leak......................
so now the water pump has to come off....... after I just did a flush and refill.
omg........to understand this better, so nowadays no green coolant is good anymore ? and the green dex cool I've been using for the last few years is considered incorrect.
Dex-Cool was never spec'd by GM for any C4 made before '95 and would be a bad choice for any C4. Period!
Any old type "green" silicate/phosphate ethyene glycol coolant would be fine for your C4. The problem is not very many coolant manufacturers make it anymore. You can still get some made by Peak and I'm pretty sure Peak also makes NAPA's "old green" house brand. If you don't mind annual coolant flushes it will work just fine.
