C4 Steering Column
Old Dec 5, 2008 | 06:33 AM
ronzboyz's Avatar
ronzboyz
7th Gear
Default C4 Steering Column
The steering column is loose on my 85 Vette. If I hold it down it seems secure to the bottom, left and right. I have seen a diagram and see that there are two bolt holes. How do I get these bolts to secure the column as painless as possible? From the dash behind the display or from under the dash?
RonzBoyz @aol.com
Old Dec 5, 2008 | 10:35 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
RonzBoyz @aol.com
Here is a link for a 92, with the exception of the air bag, should be pretty close.
http://domesticmisfits.net/forums/viewtopic.php?t=124
Call Tom Reina, 864 287 9990. He is a Corvette Steering GOD, helped me out significantly, as this is his livelyhood
Old Dec 5, 2008 | 11:05 AM
josephf31's Avatar
josephf31
Default If you have the tilt wheel
RonzBoyz @aol.com
The pivot pins and housing are worn, do a search and you will find many articles on the issue. It's not an easy fix, you need dig way down into the guts of the steering column...
To C4 Steering Column
