Intermitent no spark
Old Dec 6, 2008 | 12:22 AM
yellow dragon's Avatar
yellow dragon
Default Intermitent no spark
1991 A4
Will start and run for about 30 minutes, then stalls with no restart, im getting no spark. If left over night or for a few hours it will restart and run for an unknown period of time. This happens whether just idling in the garage or driving at any speed.
So far-
Replaced cap and coil
ran for a few hours and thought problem was fixed but to my avail it stalled again, restarted for about 3 minutes and then stalled for good, no spark, until the next morning at which time it ran for another hour and stalled.
Getting over 7 volts at dist. Battery terminal
Can anyone help me find a place to start? Could this be an ECM problem?
Yellow
Old Dec 6, 2008 | 09:09 AM
WW7's Avatar
WW7
It sounds like an (ignition control module) to me , this can cause intermittent starting and dying. I believe these can be tested,new ones run about $50.00...WW
Old Dec 6, 2008 | 11:12 AM
yellow dragon
thanks, it started up this morning so ill wait till it dies and test the ICM
Old Dec 7, 2008 | 12:23 AM
jfb's Avatar
jfb
ICM's with a lot of hours on them typically have your symptoms, that is, when they get hot, they quit, but when you cool them off, they work again.
Old Dec 8, 2008 | 04:14 PM
yellow dragon
Replaced the ICM, fired right up!!!! let it run for about an hour and go through its heat cycle a few times, drove it about 40 miles and no problem.
Seems to have fixed the problem!!!!
50 bucks and 15 minutes of work
Thanks again to everyone for the help, i can now live the C4 lifestyle again!!!!!!!!!!!!
Yellow
Old Dec 9, 2008 | 09:57 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Lucky you got a warning. When my ICM died suddenly, it took my coil out with it! Flat-bedded me like a ****!
Old Dec 12, 2008 | 05:41 PM
yellow dragon
well my cap and coil were shot when the problem arose, the coil was arcing all over the place and the cap was in rough shape so i think they all went at the same time.
200 miles and still running strong, im a happy camper. Cant believe i let the car sit for six months because of a 40 dollar part.
thanks again
To Intermitent no spark
