testing after opti change
Old Jan 16, 2002 | 01:41 PM
emoshn's Avatar
emoshn
Default testing after opti change
I'm about to change the optispark, plugs and wires in my 92. I intend to test fire the engine before I reinstall the water pump, belt, etc.. Of course, I'll put the front crank pulley back on before I fire it.
Anybody see any problems with this dry firing ? Just don't want to get it all back together and find out I messed up somewhere and have to tear it all down again.
Old Jan 16, 2002 | 02:13 PM
olephart's Avatar
olephart
Default Re: testing after opti change (emoshn)
I guess you will have some sensors inoperative depending on what parts you leave off. That may have some effect, but I guess it would start.
Other than a defective opti, I'm not sure what could go wrong except for forcing the cam pin in the wrong slot or crossing the wires. You can avoid all of this with a little care and planning.
I just did it and only had one problem. I forgot to close the air valve on the water pump. When It started, water was spraying all over the place.
My heart stopped. Thought I had a big leak and would have to pull all that crap off again. It is mildly humorous now.
Old Jan 16, 2002 | 02:45 PM
GlockLT4's Avatar
GlockLT4
Default Re: testing after opti change (olephart)
I did the same thing when I change my opti and pump. I left the pump off, but attached the ECT sensor as well as put the MAF back on. I ran it for about 20 seconds or so just to be sure I had it on right and all cylinders were firing.
Old Jan 16, 2002 | 07:30 PM
emoshn's Avatar
emoshn
Default Re: testing after opti change (Glock'94)
sounds good glock. Thanks. Any advice before I get started?
Old Feb 3, 2002 | 04:25 PM
GlockLT4's Avatar
GlockLT4
oops.. forgot to put e-mail notification on. I'm sure you've started it up by now, but the only tips are to double check your wires and make sure nothing is touching the headers.
To testing after opti change
