???? Catalytic Converter Question ????
Old Dec 6, 2008 | 10:09 PM
ol school's Avatar
ol school
Default ???? Catalytic Converter Question ????
So, Im having to change out my converter, Id like to go
high performance,or Hi Flow keeping it legal as well.(Texas)
Ive seen some that are univeral and some that are direct bolt ons
there about $100.00 differance
Any suggestions ?
I plan on adding a aftermarket exhaust system
as soon as I get this girl running right.
96 LT1
Old Dec 7, 2008 | 12:39 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Have you tried a forum search on them. Lots of different ones.
http://www.randomtechnology.com/universal.html
Old Dec 7, 2008 | 09:19 AM
Joe C's Avatar
Joe C
i went the magnaflow, freeflow, direct fit route for my 90, (p/n 93441). when holding this thing up to the light, other than a fine mesh screen, you can see straight throught it. i got it at summit racing retail store - $134 less a $20 off coupon they sent me. got the magnaflow front y-pipe w/ freeflow precats on order - next a corsa cat back (but after christmas) -
Old Dec 7, 2008 | 10:20 AM
jmeyer58's Avatar
jmeyer58
Just be careful with aftermarket cats. I have had several cars manufactured after 95 turn on the check engine light when a cheap aftermarket cat was installed. The computer system measures cat efficiency and with some of the inexpensive cats the code gets tripped. That being said, I haven't used a Magnaflow and they are a reputable company so there should be no problem.
Old Dec 7, 2008 | 11:47 AM
M. Schumacher's Avatar
M. Schumacher
The universal ones are going to require some fabrication. I'd rather have a direct fit.
Old Dec 7, 2008 | 04:04 PM
j-wireman's Avatar
j-wireman
Joe, why are you going with the front Y-pipe with cats instead of one without?
Also, have you found any flow numbers for the various cats that made you decide on the Flowmaster over the others?
Just trying to gather as much info I can to make an intelligent decision.
Mike
'90 'vert
Old Dec 7, 2008 | 09:10 PM
ol school's Avatar
ol school
Originally Posted by joe c
i went the magnaflow, freeflow, direct fit route for my 90, (p/n 93441). When holding this thing up to the light, other than a fine mesh screen, you can see straight throught it. I got it at summit racing retail store - $134 less a $20 off coupon they sent me. Got the magnaflow front y-pipe w/ freeflow precats on order - next a corsa cat back (but after christmas) -
ill look into summit, thanks
Old Dec 7, 2008 | 10:52 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
When people are contributing here, you should note the OP owns a 96 LTx motor. They don't have a main cat. They have two fronts. This is different than OEM L98s. (Actually the oldest C4s only had a main cat.)
IMO, (for the L98 contributors) you can consider using one main cat on L98s now. Originally, the fronts handled NOx gas while the other carbon (or it might be visa-versa).
Newer cats are 3-way. One unit handles both issues.
I can't say what the best LTx option is -- but I'd consider Magnaflow first. I was happy how their spun CATS worked on my L98 (in the front Y).
Old Dec 8, 2008 | 04:03 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
When I had the Stainless works LT headers installed on my LT1 I of course could no longer use the stock cats and went with RT highflow bullitt cats and have been very happy with them. The body of the unit is stainless so they are a bit more expensive.
And as noted above you have an LT1 so you are going to need two cats for your true dual exhaust system.
Old Dec 10, 2008 | 07:21 PM
j-wireman's Avatar
j-wireman
Sorry, GREGG. My mistake. I didn't tread the last line(s).
Thanks for the info, too.
To ???? Catalytic Converter Question ????
