wheels, wheels, wheels
They look really good on the car too. :D
I was told I got the "style" points at the first autocross that I had them on the car.
They can also be re-built if you should booger up a rim. John will put a new ring on for about $100.
The Z06 rims are Magnesium, hard to get and can't be repaired (easily at least). I know people who went to great lengths to get a second set from GM to use for the race-tires. They had to sign an affadavit that said they were stolen to get them from the general (and they were paying for the darn things out of their pocket!)
Did John build you race wheels or street wheels? Do you mainly drive the car for track events?
Ok I 99% sure that Z06 rims are aluminum. Forged in 01' & cast in 02'. No comment on what I had to sign & swear to to get mine. :p: I will say it wern't easy.
Neal
I can tell you that my AFS wheels weighed in at a hefty 37 lbs/ea for that cast aluminum. My OZ's (while they look very good) weighed in at a hefty 43 lbs/ea. The forged CCW's were only 22.4 lbs/ea. That's a pretty hefty un-spring weight reduction. I think the Z06 wheels are in the 30 lbs/ea range.
Cast wheels can't come anywhere near the lighter weight of a true 3-piece (unless they are Magnesium) because they need to have a pretty thick outer area for the tire to mount on. Many times, there are casting imperfections and there will be pin-hole leakes through the casting. On a 2 or 3-piece wheel, the outer "rings" are 1/8" thick aluminum spun and formed into shape. You can't beat them for strength, and repairing them is as easy as pulling the bolts, taking them apart and replacing the bent ring.
Try that with a cast wheel sometime...
I can tell you that after researching all the choices of 3-piece wheels, that John was about 60% of the cost of his nearest competitor (Kinesis) and Fikse wants about $3,800/set for the same thing.
I couldn't see spending $3,800/set for wheels that I only use for racing. These are hands-down the cheapest 3-piece wheels you'll find brand new. John's customer service is 1st-class. These centers are cold-forged and tough as nails. They have great ventilation, and work well on the car.
And, you gotta know that they work pretty good and are reasonable in price when lots of Motorola Cup and Speedvision GT teams are using them for racing.
Just remember that opinions are like **** pores...everyone has one and most of them smell. I don't judge you, so please don't judge me.
I don't have time for small minds or bigots.
