Real time help needed. O-ring size CPS
Old Dec 13, 2008 | 03:30 PM
MikeC4's Avatar
MikeC4
Default Real time help needed. O-ring size CPS
'96 LT4
Hey guys, I just got my CPS off and the O-ring has seen better days. Can someone tell me what size this rubber O-ring is ??
If you don't know exact size, do you know if it is SAE or Metric??
I hate sitting on the floor at Autozone trying to match up O-rings. Done this too many times...
BTW....many thanks to CF member 96GS#007 for his great advice to jack the engine up about an inch to get to the 8mm CPS securing nut. Any other way would be crazy.......takes just a little extra time to jack up the front on both sides, loosen the 18mm motor mount bolts, then jack the engine up with a piece of wood under the oil pan. Thanks !
Old Dec 13, 2008 | 03:56 PM
WVZR-1's Avatar
WVZR-1
The GM part # is 10476885 and the AC/Delco is 219-194. I'm assuming
"CPS" is crank position sensor. You might either just catch the correct seal or see if maybe your "AZ" can interchange the information!
It's only 3:00 or 2:00 in your time zone you could likely catch a dealer if you start "NOW"!!
Old Dec 13, 2008 | 04:03 PM
MikeC4's Avatar
MikeC4
Thanks WVZR-1. I'm on it.........
To Real time help needed. O-ring size CPS
