Fog light troubleshooting help!!
Old Dec 13, 2008 | 06:12 PM
10.5Vette's Avatar
10.5Vette
Default Fog light troubleshooting help!!
Putting my 93 up for the winter and decided to fix a couple of small problems. One I'm working on now is the fog lights don't work. Never have since I bought the car in the spring. Today I checked the bulbs and both look new, replaced them with some spares just to check and still no lights. Cleaned up the grounds coming from the wires under the hood in the front corners, still no good. On the dash the green light comes on when I turn the switch on, so I'm guessing there's power there. All other lighting systems work fine. I don't see a fuse for them. Any ideas, help, suggestions?
Old Dec 15, 2008 | 11:46 AM
josephf31's Avatar
josephf31
Default Check the relay
There should be a relay for the fog lights up under the passenger side of the dash, on my '91 there are 3 in a row, I forget which one is the fog lights, if you don't have a manual maybe someone with a 93 manual can tell you, or I can look in my '91 manual.
Joe
Old Dec 15, 2008 | 05:45 PM
10.5Vette's Avatar
10.5Vette
I have a 93 manual on the way. I'll check for the breaker location when I get it. Thanks for the advice. I knew there had to be something there.
To Fog light troubleshooting help!!
