Low Profile Floor Jack?
Old Jan 17, 2002 | 01:42 PM
GregP's Avatar
GregP
Default Low Profile Floor Jack?
Anyone know a source for a very low profile floor jack (other than the $600 racing aluminum units)? I need one that goes to 3" when lowered to get it under my car. I already took the wheels off of one of my jacks which helps, but I still have to "lift up" on the frame to slide it under.
Thanks - Greg
Old Jan 17, 2002 | 02:11 PM
Camvette's Avatar
Camvette
Default Re: Low Profile Floor Jack? (GregP)
Drive it up on a couple of 2x8's then place your jack. Should give you plenty of space. :rolleyes:
Old Jan 17, 2002 | 02:57 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I use a Craftsman 3 ton floor jack with the lifting puck removed to get under the lowest cars I have had. I can measure the exact height if you need it.
Old Jan 17, 2002 | 04:33 PM
GregP's Avatar
GregP
Default Re: Low Profile Floor Jack? (Vette92)
Camvette - Problem is it doesn't exactly run yet, and it's a real bitch to push it up on a pair of 2 x 10's
Vette92 - I have the wheels off of my Craftsman jack, but couldn't figure out how to remove the lifting puck. How did you do it on yours?
Thanks - Greg
Old Jan 17, 2002 | 04:44 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Mine just lifts right off and leaves a nice 4"x4" flat surface. I would say there may be a pin, but if you have removed the wheels you probably looked pretty good at it. Hmmm.
Old Jan 17, 2002 | 10:05 PM
90pololt4's Avatar
90pololt4
Guy's,
About a year ago we had a group purchase here for and ultr low profile jack. I purchased one and it has been great. My car is lowered as low as it can go and I can get it under any where. I will find the company's name and number and post it here for you. It was about $450 at the time with freight.
Old Jan 17, 2002 | 11:49 PM
SPEEDEMON's Avatar
SPEEDEMON
Greg
I have the OTC floor jack which is one of the lowest I have found which is 3.75" I purchased this from my Snap-On dealer for $255.00. Here is a site that has the spec if that can help you.
http://www.ntxtools.com/shopequipmen...nt/otc1727.htm
Old Jan 18, 2002 | 12:56 AM
Juliet's Avatar
Juliet
Problem is it doesn't exactly run yet...
:lol:
I must say you C4 guys are good! :yesnod:
To Low Profile Floor Jack?
