I was watching one of those outrageous video shows and I saw one where a dirt track car lost a tire and went a hundred yards or so and the tire caught up to the car and rolled back on to the wheel.
Edit: here it is
I remember this one. That was insane! I bet the driver did not even know.
fyi, those tires are made specifically for dirt track, very flexible sidewalls, and run as low as 8 psi...bead breaks are common, tossing the tire off the car and running it again after remounting not unusual...typical pit action if one guy pulls a tire off and installs another on the ground,5 minute job at max using just a "pry bar"
