Mem-Cal Interchangable?
Old Jan 17, 2002 | 04:56 PM
AlexS's Avatar
AlexS
Default Mem-Cal Interchangable?
After looking up all the EPROM programing info.
once thing I couldn't tell if it is ok to do.
Can I put any mem-cal module from any olde GM product, say a 90 Buick Century and reprogram the EPROM and put it in my 93 LT1?
basically, I don't want to butcher up the stock mem-cal module. and don't mind paying a couple of $ and pull a few used modules from a junkyard, then reprogram those instead of my stock unit.
Thanks for your comment in advance.
Alex
BTW, I am going to solder a AT29C256 EEPROM in it so that will miniumize any virbation connection problems with ZIF sockets
Old Jan 17, 2002 | 06:43 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: Mem-Cal Interchangable? (AlexS)
you need to make sure it is from a similar application.... a V8 memcal on a V8 car. The resistor networks on the memcal hold limp-home mode as well as cylinder select info. If you run a V6 memcal on a V8 car, you'll get a code.
The other thing you'll run into is that the ECM is different between the Buick and your Corvette, so you also need to make sure the memcal came from the same ECM.
Best thing to do is find as close to your application as you can.
Ludis' website has a great cross-reference of ECM numbers and applications. For instance, an S-10 uses the same ECM as '86-'89 Vettes... 1227165. The memcal is different though.
Old Jan 19, 2002 | 01:58 PM
AlexS's Avatar
AlexS
Default Re: Mem-Cal Interchangable? (Marcho Polo)
So if I pull a v8 F-body's Memcal out. It shold be close enough?
BTW, what is Jeff's E-mail? I might go with new if the Junk yard decided to give me hell.
Alex
Old Jan 20, 2002 | 03:09 PM
Rich B.'s Avatar
Rich B.
superchevyparts@worldnet.att.net Or just page 18carfan...
I'd say get a 350 SBC MemCal...That should be close enough...BTW: A 165 MemCal new runs about $36; a 730/727 MemCal about $48...
And as a bonus, you get the latest BIN with the new MemCal...(They do change them)...
Old Jan 21, 2002 | 11:27 AM
AlexS's Avatar
AlexS
Default Re: Mem-Cal Interchangable? (Rich B.)
Guys,
Thanks for the Info. I am going to order a new Mem-cal for back up and then retrofit the old one with a Flash EPROM.
Thanks again. I'll be posting again when I get the new mem-cal.
Alex
To Mem-Cal Interchangable?
