Blower motor problem
Old Dec 19, 2008 | 09:36 PM
95davev's Avatar
95davev
Default Blower motor problem
I've only had my 95 for about 4 months. I don't recall having any problems with the blower motor when I was using the AC, but now with the heater it will not always turn on.
It has the electronic climate control.
First question: With the heater in manual mode, should the fan turn on regardless of engine temp, or does the engine need to get to a certain temp before it will come on? I would think that's only in the "auto" mode, correct?
The blower usually doesn't come on until the engine is at about 185*, but even then about 2/3 of the time it still doesn't come on. Sometimes, after about 30-60 minutes of driving all of sudden it decides to turn on.
All of the buttons on the control panel are working, and the little bit of ram air that flows due to the cars speed will come out of the selected location and be of a temp corresponding to what temp is set. The fan speed indicator will cycle from 1-10. No unusual noise when the blower does decide to operate.
Any troubleshooting suggestions?
Old Dec 19, 2008 | 11:09 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
in any mode, the fan speed or the fan running or not is not dependent upon coolent temp.
Old Dec 19, 2008 | 11:12 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
When you push the fan up button does the fan come on? That takes it out of auto mode.Since you did not fill out your profile we can't see where you are but if the ambient temp matches the interior temp the fan will be on low speed.
Old Dec 20, 2008 | 07:55 AM
95davev's Avatar
95davev
Thanks, I didn't think it should be dependent on coolant temp, but wanted to rule that out as a possible problem.
I'm in St. Louis. Temps been in the teens. When I select a higher fan speed, the indicator will increase all the way to 10, but the blower does not respond, but it is not simply a bad blower as it will sometimes work fine. I'm thinking a relay or a connection problem.
Old Dec 20, 2008 | 08:26 AM
rodj's Avatar
rodj
The blower gets it's power direct from the battery THROUGH the blower control module ( fancy relay)
These commonly go bad , generally turn blower on at random , even when ign off.
Module is mounted inside the A/c ducting in engine bay.Look for two big weather pak plugs in plate held by three screws.
Old Dec 20, 2008 | 09:29 AM
95davev's Avatar
95davev
Thanks, Do you know how I would test it?
Old Dec 20, 2008 | 10:34 AM
Redeasysport
Unless you have an electronic back round there is no way. Sounds like a cold solder joint or bad connection. Try shooting the connector with some contact cleaner and see what happens. If nothing replace it.
Old Dec 20, 2008 | 10:51 AM
95davev's Avatar
95davev
I appreciate your help. I just wish I could test a $150 part prior to replacing it. When I do a search on heater control module failures, It seems everyone's problem with a bad module is the blower runs with the ignition off. Mine has not done that at all. First I will try cleaning the contacts as you suggested.
Old Dec 20, 2008 | 11:43 AM
MikeC4's Avatar
MikeC4
you need to check the blower resistor, which only costs $17 . I have had these go bad on some C3's in the past. When they go out, you usually loose your high speed fan. These are nothing more than metel spun resistors and they carry alot of current. When they go bad, they somply open up like a burnt out fuse. They are easy to visually inspect. If your '95 doe's have this type of resistor, it usually sits right on top of the evaporator housing. But I don't know if your model uses this.
http://www.ecklers.com/product.asp?p...3&dept_id=1155
Old Dec 20, 2008 | 11:57 AM
95davev's Avatar
95davev
Doesn't seem like a resistor, because when it decides to work it works on all speeds.
Old Dec 20, 2008 | 01:06 PM
Redeasysport
You could always try to ask another local 'Vette owner to borrow his to ensure it is indeed the trouble.
Old Dec 20, 2008 | 01:09 PM
95davev's Avatar
95davev
Great suggestion! I just went out to try and troubleshoot some connectors, and wouldn't you know it, it's working fine right now.
Old Dec 20, 2008 | 06:15 PM
rodj's Avatar
rodj
The C68 electronic air doesn't has external resistors.
Everything is contained in a nice $$ unit.
Old Dec 20, 2008 | 06:49 PM
Redeasysport
To Blower motor problem
