TPI question
Old Dec 20, 2008 | 11:04 PM
buddylee432's Avatar
buddylee432
Default TPI question
On the 85 TPI below the throttle body is an outlet. Is this a water outlet and if so what do you connect it to. There is a water outlet below it. Also is this the only water outlet around the throttle body?
Old Dec 20, 2008 | 11:10 PM
John A. Marker's Avatar
John A. Marker
It connects into the heater pipes. You can by-pass this by taking the hose on the drivers side that goes into the TB and using a coupling connect it to the hose that exits on the drivers side ot the TB. This results in a TB that runs cooler. The reason for the coolant running thru the TB is for those areas that have very low winter temps.
