Looking for stainless steel mufflers only with large dual tips 3" to 4" only for a 91. Any input on the best place for just mufflers? Corsa, Mags etc.. Thanks
Interesting. I've never seen Corsa sell mufflers only
since it employs the same patented technology, could they reproduce similar performance and sound compared to the cat back sytem for a fraction of the cost?
heck i guess if you hire a muffler guy at 85 bucks an hour forget about it
Check Summit Racing for Magnaflows. You may not find anything available with 4" inlet and outlet.
But the typical oval shaped muffler is about 19" long including the inlet and outlet pilpe (14" to 15" in case length) so you would need some sort of extension tip to clear the rear bumper facia. The stock Corvette muffler sits back some and the universal style mufflers will sit in pretty much the same place as stock mufflers.
Most good quality muffler cases are made from T-304 stainless; some are polished, some are not.
