Additives - Add or Subtract?
Old Dec 23, 2008 | 06:19 PM
BluRay's Avatar
BluRay
Default Additives - Add or Subtract?
Alrighty all this is going to rank right up there with the oil thread I am sure, and no doubt cause some black eyes.
How many of you are using additives? Fuel, engine oil, transmissions auto/man., cooling, differential.
What results have you seen? No change, definite change, fixed everything right down to the tire pressure?
Old Dec 23, 2008 | 06:45 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Well as you read the Diff requires LS additive.
The only tranny stuff that works is not a cure all just a cleaner and should be installed at a reputable shop.
Mobile One is all you need.
Some people use water wetter in the radiator and GM recommends a couple of their pellets when changing fluid.
Old Dec 23, 2008 | 06:47 PM
BluRay's Avatar
BluRay
Yeah I should add here that this is not a poll for what I should put in my car. I am a believer in OEM, but with all the crap on the market today I am just curious as to what if any results are seen.
Old Dec 23, 2008 | 07:00 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The only additive I use is Lucas in my fuel and I added a bottle of prolong in my auto tranny 4 years ago.
Dexcool, Mobil one, Castrol TWS and Royal Purple are plain.
Old Dec 23, 2008 | 07:49 PM
geogolf's Avatar
geogolf
Default additives
i use marvel mystery oil in my fuel , nothing in oil
Old Dec 23, 2008 | 08:29 PM
WW7's Avatar
WW7
I have read and been told by many who know that as long as you change the fluids in your car at perscribed intervals there is no need for additives of any kind. I have found this to be true. WW
Old Dec 23, 2008 | 08:32 PM
BluRay's Avatar
BluRay
Old Dec 23, 2008 | 10:01 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default additive
Lucas, my cars and my harley.
Old Dec 24, 2008 | 05:09 AM
Weav's Vet's Avatar
Weav's Vet
I've used Seafoam in gas a few times. Also ran it through the brake booster vacum hose to the intake. Lucas in the auto tranny just for preventive maintenance. Both seemed to help. The Lucas especially.
Old Dec 24, 2008 | 06:04 AM
BluRay's Avatar
BluRay
Really the reason I pose this question is because of all the stuff that is out there and all those who swear by it. It seems that out of all of it you never hear of any engine doing anything that is most likely wouldn't have done anyway.
The only thing that I have seen make any difference is GM's Top Engine Cleaner. This of course only if it is administered through an injection apparatus. The stuff will clean injectors, intake valves, and pistons to a friggin' shine! I can't count the number of Ford V-6's that have come in for poor cold idle, tip in hesitation, and poor drivability that I have cured with this. Much to the absolute delight of the owners. It's sad but I run into a whole whole lot fewer Chevy's that benefit as much as Fords do.
I am a firm believer that anything that you dilute in 20 gallons of gas is not going to do squat for ya. I'm really trying to prove my beliefs to be out of line with newer innovations in additives. So far I have yet to find anybody that can say they actually improved anything or relieved any symptoms.
No offense to any of you who use this stuff you understand. All to his own, and if your ride is riding happy with it, rock on.
Old Dec 24, 2008 | 07:44 AM
runner140*'s Avatar
runner140*
I drive somewhere in the area of 20,000 miles a year and only use Mobil1 every 3,000 to 5,000 miles. SeaFoam once a year, half in the gas tank and half in the vacuum hose of the brake booster.
The above and good maintenance got me to over 155,000 somewhat trouble free miles.
Old Dec 24, 2008 | 08:12 AM
WW7's Avatar
WW7
I do clean my engine out once a year with Seafoam, but I don't consider that an additive unless you put it into your oil or gas. I just run it through my brake booster to clean out carbon, and of all the produces out there I consider it one of the best. I have seen motors torn down before and after using Seafoam at one of the seminars I attended when I was on the Pro Staff for Mercury outboards and the difference was unbelieveable...WW
Old Dec 24, 2008 | 09:24 AM
MAGDANA's Avatar
MAGDANA
Check my website home page for a link to an article on additives. It's right below the FREE graphic.
Joe Johnson
www.MAGDANA.com
Old Dec 24, 2008 | 09:37 AM
BluRay's Avatar
BluRay
Joe Johnson
www.MAGDANA.com
Yup, kinda supports my thoughts. I know all our mfr. specific training pretty much laid it out as satans wine.
Old Dec 24, 2008 | 11:36 AM
toptechx6's Avatar
toptechx6
Like you BluRay I have always believed clean oil and lubricant as specified by the manufacturer is all that is required. I will say I have tried some Lucas products on old high mileage beaters and was pleasantly surprised with the results.
Old Dec 24, 2008 | 12:39 PM
BluRay's Avatar
BluRay
lol, I poured a V8 sized bottle of liquid rebuild in a chevy 2.4L S-10 that I had. Truck had around 275,000 pretty hard miles on it and rattled, smoked, knocked, wiggled, you name it. Ran it for around a 1,000 miles and changed the oil. It actually cut the smoke and noise in half. It seemed to be a little smoother, with no power increase.
3 months later it parked a rod and piston at the top and sent the rod cap out the side of the pan. We did drop the pan on it to find the slime had built heavy everywhere and made a neat carbon mold on anything that didn't turn.
at that point it could have been the goo or just it's time, we'll never know
Old Dec 24, 2008 | 01:34 PM
rick lambert's Avatar
rick lambert
SeaFoam once a year, usually just before emissions, only time I failed I hadn't done the SeaFoam, came home did it, changed the oil and passed. I also use Techron sometimes.
Old Dec 24, 2008 | 09:32 PM
BluRay's Avatar
BluRay
You know I have never heard anything negative about the Techron laced fuels???
huh.......
Old Dec 24, 2008 | 09:52 PM
MacManNM's Avatar
MacManNM
I am a huge believer in "greased lightning" injector/carb cleaners. I had a yamaha back in the 90s that ran like crap, I added the prescribed amount and almost instantly the thing started running like a raped ape! I've used it in a bunch of vehicles since, with great results.
To Additives - Add or Subtract?
