Underhood Lights
Old Jan 18, 2002 | 12:58 PM
HTRK-1's Avatar
HTRK-1
Default Underhood Lights
I put the hood up on my '93 and the lights do not come on. Is there a switch or a fuse somewhere? Also, the light on the vanity mirrors, when they are switched on are they supposed to shut off with the ignition. My wife turned the passenger side light on and forgot to switch it off, before putting the visor back up. Thanks for the info
:cheers:
[Modified by HTRK-1, 4:59 PM 1/18/2002]
Old Jan 18, 2002 | 01:01 PM
scorp508's Avatar
scorp508
Check to see if hte hood lights are plugged in. Lots of people unplug these for when they are working under the hood. They are mercury switches.
As for the visor, it should shut off when the ignition is off so that it doesn't kill your battery. Mine does.
Old Jan 18, 2002 | 01:05 PM
bogus's Avatar
bogus
Default Re: Underhood Lights (HTRK-1)
the hood lites are supposed to be run by a mercury switch. you may have a cut wire or blown bulbs
the prior owner may have installed a hood lite kill switch... check for such a beasty. I don't know where they are supposed to hide.
I don't know what to say about the visor lites... mine go off with the key...
Old Jan 18, 2002 | 02:32 PM
HTRK-1's Avatar
HTRK-1
Default Re: Underhood Lights (bogus)
Thanks guys, I'll look for the connector tonight. I'm sure someone probably diconnected it while working on the car. I will also double check the visor lights, I can't wait for my owners manual to get here, so I dont feel like a :conehead asking these questions.
Old Jan 18, 2002 | 02:52 PM
Red Dwarf's Avatar
Red Dwarf
Don't know if was covered, but the fuse for your UH/lights is on the back of the left cornering light, across from your airpump......... :cheers:
Old Jan 18, 2002 | 03:05 PM
Goody's Avatar
Goody
Default Re: Underhood Lights (lou sylvestri)
No air pump on LT1's. Didn't need it. Anyway, check the fuses for the UHlights. The vanity lights in my 93 go off with the key so no worries there. If you remove the glass light covers to check the bulbs, make sure you don't torque them down excessively because they will break. Trust me... :smash:
Old Jan 18, 2002 | 03:47 PM
HTRK-1's Avatar
HTRK-1
Default Re: Underhood Lights (Goody)
Thanks, I'll check the fuse and the bulbs. I thought I read somewhere the LT1's used an electric air pump to pump air to the catalytic converter for emissions? I could be wrong, I read so many car books and mags.
Thanks for the info.
:cheers:
Old Jan 18, 2002 | 04:47 PM
MarkBychowski's Avatar
MarkBychowski
There is an air pump -- it's just an electric one. It's located down by the charcoal canister underneith the driver-side headlamp.
Old Jan 18, 2002 | 05:03 PM
Goody's Avatar
Goody
Default Re: Underhood Lights (MarkBychowski)
My bad, I forgot about the hair dryer up there. . . I was thinking about the one the L98 guys hate and eliminate. D'oh!! :conehead
Old Jan 18, 2002 | 09:40 PM
HTRK-1's Avatar
HTRK-1
You guys are awesome. With friends like you, who needs the Chevy Dealers? have a great weekend all! :cheers:
Old Jan 18, 2002 | 09:43 PM
scorp508's Avatar
scorp508
What AIR pump? :D
Old Jan 18, 2002 | 10:22 PM
FIBERGLASMD's Avatar
FIBERGLASMD
There is a connector on each light down below the light.
Old Jan 19, 2002 | 12:32 AM
shepsvettes's Avatar
shepsvettes
On a 93 theree is a fuse for the underhood lights.It,s located near the air pumy in the lower front section. I took the fust out of the holder on mine and got a toggle switch that pluged in in place of the fuse made a really cheap way to turn the hood lights off and on, the switch is hidden where you can't see it works great :cool: :cool: :cool:
Old Jan 19, 2002 | 12:39 AM
GlockLT4's Avatar
GlockLT4
Default Re: (scorp508)
:yesnod: :yesnod:
Old Jan 19, 2002 | 08:14 AM
jgrice's Avatar
jgrice
I would like to install a kill switch for when I am working on the car or at shows.
Can someone provide directions for how best to do this?
Thanks!!
Jeff (91 convertible)
To Underhood Lights
