quick question alternator
Old Dec 27, 2008 | 07:50 PM
ladystoy69's Avatar
ladystoy69
Default quick question alternator
i have a 85 corvette and need a alternator, so i would like to get a high amp output chrome one. problem is every chrome one i look at that says it will fit/work also says it will work with other cars too (most listed are not reverse rotation like ours) so i guess my question is does it matter which way the alternator turns? or because of our belt routing maybe it turns it the same way as lets say camaro?
let me know........ thanks
Old Dec 27, 2008 | 08:02 PM
Iroc57's Avatar
Iroc57
If I remember correctly the alt pulley has grooves, meaning it turns clockwise. When I did my swap I used the original alt and it worked.
It's a 91' so there may be a difference though
Old Dec 27, 2008 | 08:27 PM
JimiHendrix's Avatar
JimiHendrix
Just buy a CS-144 and be done with it. (12o amp model). It doesn't matter which direction the alternator is spun, it will still put out DC voltage in the correct polarity.
Old Dec 27, 2008 | 08:34 PM
CFI-EFI's Avatar
CFI-EFI
The C4 L98 water pump is reverse rotation. The alternator is not.
RACE ON!!!
Old Dec 28, 2008 | 12:34 AM
BluRay's Avatar
BluRay
Also don't forget that chrome anything has a shorter(in this case MUCH shorter) life expectancy. Chrome insulates and helps to create a CRAP LOAD of heat. Depends on what you do with your car, and if your willing. Just my.02
Old Dec 28, 2008 | 12:42 AM
JimiHendrix
Oh really?....
Old Dec 28, 2008 | 12:44 AM
BluRay's Avatar
BluRay
Originally Posted by JimiHendrix
Oh really?....
YEAH F*CKIN REALLY!
To decrease the source of heat from the engine you may try shielding. To do this it is suggested that you purchase a sheet of aluminum, available from your local hardware store. Form it around the alternator and attach it to the engine. DO NOT ATTACH OR TOUCH THE ALTERNATOR. This will help direct the heat around and away from the alternator reducing the killer heat. Also, stay away from pretty plated chrome or gold alternators. The plating prevents heat dissipation causing the alternator to hold more heat in. Remember, heat kills!
http://www.cardiscountstereos.com/Alternators.asp
Old Dec 28, 2008 | 01:48 AM
JimiHendrix
Dark colors absorb heat.....lighter and reflective surfaces reflect and dissipate heat better. The source of the heat is from the engine compartment. . . .not from within the alternator. . . . otherwise I would agree with you....
YOU WANNA STEP OUTSIDE ON THIS??!?!?!?!?......
YEAH F*CKIN REALLY!
Old Dec 28, 2008 | 02:44 AM
BluRay's Avatar
BluRay
Well considering we are not setting these alternators out on the curb in the sun color has absolutely nothing to do with it. It's the fact that the thicker and additional plating hinders the alternators ability to radiate heat. I'm not sure where you get your notion that the heat does not come from within. Go run your car for an hour with the hood open and grab hold of the alternator REAL TIGHT. Let me know when your hand heals. Corvettes inherently have a lot of under hood heat as well that only compunds this issue.
This is far from the point of the post. I was only letting the OP know that chrome alts. do not last nearly as well as non. If he uses his car for often driving especially in the city or traffic this can be a real draw back.
IF we go outside only one of us is coming back in.....
Old Dec 28, 2008 | 02:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
BLURay
Easy there brother
YEAH F*CKIN REALLY!
Jimi
Old Dec 28, 2008 | 02:54 AM
BluRay's Avatar
BluRay
BLURay
Easy there brother
CFI, BluRay. BluRay, meet CFI
LOL, well I hope it is just good will charged conversation. I am just not fond of getting a ribbing or eye roll on something as if I am just saying it for the fun of it. If there is something that I am not sure about or is an opinion I will state that fact. Don't get me wrong I'm far from perfect and make mistakes......lots of em', but unless you can support your argument don't argue with me
The whole point here is to help each other with information we may not have or have considered. That was my attempt here as well.
Old Dec 28, 2008 | 01:11 PM
CFI-EFI's Avatar
CFI-EFI
That sounds like someone else I know.
RACE ON!!!
Old Dec 28, 2008 | 01:22 PM
MikeC4's Avatar
MikeC4
Originally Posted by cfi-efi
that sounds like someone else i know.
Race on!!!
are you two guys related ? :d
To quick question alternator
