Rear width?
Old Dec 27, 2008 | 07:57 PM
pipe's Avatar
pipe
Default Rear width?
Anyone know how wide in inches a Vette's rear is from outside edge of spindle to outside edge of spindle when level? THANKS Pipe
Old Dec 27, 2008 | 08:11 PM
rodj's Avatar
rodj
62 1/2' across the hub faces is a figure I have seen posted for the late models
The '88+ are 18mm wider each side than the early models on account of the different brake setup
Old Dec 27, 2008 | 08:18 PM
WVZR-1's Avatar
WVZR-1
Wasn't this just recently done?
http://forums.corvetteforum.com/c4-t...44-length.html
PIPE!
You can accomplish this yourself and the numbers will be on "the button"! With your car level on the ground measure from the inside wheel lip to the inside wheel lip on the other side. Remove your wheels and measure the "backspacing". Add the backspacing X 2 to the measurement should accomplish the task. How's that?
Old Dec 29, 2008 | 07:12 PM
pipe's Avatar
pipe
Thanks for the info guy's too bad the car's not close to me. But THANKS Pipe
To Rear width?
