B&M Shifter Install plus pics
Old Dec 31, 2008 | 07:23 AM
Caleb56's Avatar
Caleb56
I did it to my 89 with everything still on, but i didnt use a drill, took me about 2 to 3 hours. You really do notice the difference.
Old Dec 31, 2008 | 08:14 AM
djxib's Avatar
djxib
Originally Posted by Snakecharmer383
What did you pay for yours? I've seen them listed for $225 is that still the going price for them.
It was a Christmas gift; I think my son paid about $220 direct from B&M (shipping was included). He had to phone them because the C4 shifter is not available online from their site.
Old Dec 31, 2008 | 08:35 AM
djxib's Avatar
djxib
Originally Posted by rickreeves1
Good write up!
Do you have more pics of the roll bar? I'd like to see where it attaches and how you cut through the rear deck lid. Where did you get it? There arent too many convertible C4's with roll bars around here. It's something I need to do. Some good pics would really help.
Hi Rick - I get lots of questions about the rollbar, so I started a new thread here:
Rollbar Thread
Old Dec 31, 2008 | 09:43 AM
rickneworleansla's Avatar
rickneworleansla
Rollbar Thread
Old Dec 31, 2008 | 07:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ok, its been 3 hours and this thing wont budge, using a punch and small sledge. Rotohammer type drill doesnt do anything.
Any magical answer before I go insane?
Old Dec 31, 2008 | 08:27 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Which part?
Old Dec 31, 2008 | 08:30 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I just completed my B&M install, and took a full set of photos. Here's the finished job:
and of course, a picture of my baby before driving her off the ramps
Enjoy, and good luck!!
Here is a good upgrade for your Pep Boys' ****.
Link
Old Dec 31, 2008 | 08:32 PM
Jagdpanzer's Avatar
Jagdpanzer
When I installed a Hurst I followed the advise Johnny phrogs posted here and all went perfect:
http://forums.corvetteforum.com/c4-z...r-install.html
Thanks again to Johnny for sharing his knowlege
Old Dec 31, 2008 | 10:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
The pin is stubborn wont budge no matter what after over 1/2 dozen hours.Guess Ill try drilling it a little, hopefully that gets it freed some. If there werent fiberglass nearby Id put some heat to it.
Old Dec 31, 2008 | 11:01 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I used a vice to remove it. Tap did not work and likely a drill will not work either
Old Dec 31, 2008 | 11:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Vice, Im not following you?
Trans is still in the car fwiw.
Old Dec 31, 2008 | 11:28 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
How about modifying a C-clamp to be used as a press? I haven't done this, but it's a wild-azz thought....
1) Punch, grind, drill, or otherwise modity a c-clamp so the stationary side has an indentation (or even hole) in the middle of the receiving end.
2) Assuming, the clamp has a swivel head, break or remove the head (hacksaw if necessary). File or grind the end of the screw shaft to a semi-point.
3) Grind of any of the stationary side necessary to get it positioned on the shifter shaft.
4) Place point (ground in step2) on pin.
5) Crank c-clamp in
Hopefully, even if it only budges a bit, it will be enough to knock out with a punch. (part of this would be based on how well the back side of the modified clamp is indented).
another thought: If you are hitting it with a punch/hammer, use a block wedged in against the back-side of the shaft to make sure all of the hit-energy goes to driving the pin.
Old Jan 1, 2009 | 12:57 PM
  #33
djxib's Avatar
djxib
I think drilling to a depth of about 1/16 inch is a good option. In my opinion the pin gets mushroomed and the drill can remove this. Good luck...
Old Jan 1, 2009 | 01:06 PM
  #34
djxib's Avatar
djxib
Link
Hmm - I didnt know that Pep Boys sell MOMO shift *****. I'm happy with my italian **** for now!!
Old Jan 1, 2009 | 02:02 PM
  #35
PLRX's Avatar
PLRX
2017 C4 of Year
ok, then...that part should come off easy. Did you remove the C-clip? I know I did mine while the tranny was on the floor but I did not have to use a drill. I had trouble installing B&M's pin. That sucker needed some extra force to fit.
I hope someone can relate to your problem and help you. Give them few hours to get some tylenol, pepto bismol and they'll log in.
Old Jan 1, 2009 | 06:33 PM
  #36
cv67's Avatar
cv67
St. Jude Donor '05
To anyone who has a stubborn pin just drill it out, takes a few minutes.
Now to go to Osh/Lowes and get another one..
Wonder if it wouldnt be a bad idea to tap/screw a bolt in instead?
Sorry bout the hijack, didnt want to start another thread and have another dupe.
Old Jan 1, 2009 | 07:23 PM
  #37
PLRX's Avatar
PLRX
2017 C4 of Year
Glad to see you got it out. 2009 is bringing good things to you already .
To B&M Shifter Install plus pics
Old Jan 1, 2009 | 08:15 PM
  #38
cv67's Avatar
cv67
St. Jude Donor '05
Needs to bring me a set of snapring pliers so I can finish this badboy and take it for one last....ride.
Old Jan 1, 2009 | 09:32 PM
  #39
PLRX's Avatar
PLRX
2017 C4 of Year
here you go
Old Jan 1, 2009 | 09:47 PM
  #40
djxib's Avatar
djxib
Congrats!!
